UCM 7.046 (Beta) has the folowing change from 7.043
Logging in to UCM (LI) with wrong code wil send a reply of "NA" instead of "LU00" so it will not log out the UCM
This has a slight Incompatibility with Comfigurator and the Comfort apps as Incorrect login wil not be reported correctly
New versions of the software wil be required to deal with this, so this firmware is to be used for testing only
Note: This firmware has been withdrawn and replaced by UCM 7.048 because it causes incompatibilty with the applications
