UCM 7.020 - 7.023 Beta
 Posted: Sunday May 12th, 2013 06:38 am
UCM 7.020
Beta Version for testing. These changes are mainly to support future features in Comfort
Changes from UCM 7.016
  1. KD command  can have optional ID following  eg KD0141 means Key 1 from Keypad #1 so UCM can activate another keypad. Not Implemented in Comfort yet
  2. Able to handle longer DL, UL, UD commands in future depending on Comfort
  3. Implement SN serial number command to read and write serial numbers to Comfort and UCMs
  4. WD commands will not write into read only area of UCM EEPROM
  5. fixed BUG WD00 write to UCM own eeprom did not work
  6. VS disable status reports for VS command and enable when VS ends to prevent interruption of  sentence download
Known Bugs
  1. The UPLOAD button on the UCM which is supposed to read from Comfort to the UCMs U2 EEPROM does not work. Do Not use this button
  2. Read from KT03 gets error - do not use this function
The firmware can be downloaded from http://www.cytech.biz/product_details.php?item_id=220
 Posted: Monday May 20th, 2013 02:10 pm
UCM 7.022 (beta) fixes the bug found in UCM 7.020
Bugs Fixed
The UPLOAD Button on the UCM did not work. Pressing for 4 seconds should cause the configuration on Comfort to be transferred into the UCMs U2 EEPPROM
Bugs
  1. Read from KT03 gets error - do not use this function
The firmware can be downloaded from the same link
 Posted: Sunday Jun 2nd, 2013 08:26 am
UCM 7.023 (beta)  has the following changes from 7.022
  1. fix BUG from UCM 7.020 - read from KT03 by UCM did not work. CM > UCM did not send data
  2. Fix bug that u?gets no reply or 000000 when UCM ID is not polled ie when the number of  UCMs is less than the UCM's ID
 Posted: Monday Aug 5th, 2013 01:04 pm
UCM 7.023 firmware has been released
 Current time is 03:15 am
