Version 6.024 (8 July 2012)
- Fixed Bug - Reset UCM will hang for 20 seconds if no U2 EEPROM is present
- SW8-G STX switch has no function
- Watchdog.reset time from 9 to 18 seconds
- Fixed BUG from UCM 6.012 Upgrade UCM by direct connection to previous versions may fail. UCM 6.012 must only be upgraded to 6.023 and above
- Added UCM message tmxx status message for Production Test Mode
- Improved READ from EEPROM speed and to prevent hang when Read is interrupted
- RESET will recover from any incomplete EEPROM operation
- Implement runaway protection of SFR
- UCM download U2 EEPROM to Comfort will check comfort firmwwre if 6.019 then send erase command to CM before writing non-FF bytes to Comfort EEPROM to speed up transfer
- UCM Download to EEPROM will stop if 21H reply is received so will not write to Event Log area of Comfort U4 EEPROM to save time and to prevent overwriting Event log
- Fixed BUG AR did not send complete message, AR message wrong from 5.183 Affects iPhone app Restore Alarms status
- Improved upgrade UCM by Bus - applies to external UCMs only
- Use new routines for COPY EEPROM (U3)
- Cater for extended sensor array for future
- Receive RS485 buffer from 127 to 240 for longer Do Action 197 message
Change in COPY EEPROM Functions- Note that in this version, the COPY EEPROM function has been disabled. This means that the COPY, TEST, COMPARE, UPLOAD functions which address the COPY EEPROM are no longer functional.
New UCM firmware can be downloaded from http://www.cytech.biz/ucm_firmware.htmlLast edited on Monday Jul 23rd, 2012 12:14 pm by
