UCM 6.002
 Posted: Monday Jun 6th, 2011 03:17 am
The latest UCM Firmware can be downloaded from http://www.cytech.biz/ucm_firmware.html?category_id=101
Instructions for upgrading the UCM firmware can be found on http://www.comfortforums.com/forum4/1782.html
This UCM firmware applies to UCM/USB, UCM/Ethernet and UCM/232
Version 6.002 (6 June 2011)
Bug Fixes
  1. Fixed BUG from UCM 5.203  Comfort bypass zone does not get reported correctly to UCM
  2. Fixed BUG overflow of rs485 transmit buffer caused endless loop leading to watchdog reset. This does not occur in mormal; circumstances
Improvements and New Features
  1. Implemented CM command for UCM for Control Menu Commands for iPhone app.
  2. Implemented UB05 firmware Upgrade for UCM directly connected to PC. Instructions on how to upgrade the UCMs own firmware can be found in the forum http://www.comfortforums.com/forum4/2283.html
  3. DT will not be reported when seconds change only is reported from the PC
  4. Size of data in Comfort Rs485 bus message increased from 64 to 69
Please note that new systems may not come with the latest firmware due to existing sticks in the supply chain. Installers should upgrade to the latest firmware before installation. Existing installed systems do not need the upgraded firmware unless the functionality is to be updated or there are bugs to be fixed which affect the installation.
 Posted: Monday Jun 6th, 2011 06:29 am
bs85
I have a UCM/Ethernet that could do with the update.
Anyone in the UK want to arrange a firmware upgrade?
 Posted: Monday Jun 6th, 2011 10:24 am
cgiltrow
Great.  I see you've implemented my request for commands for the control menu.  Where can I get the protocol?
Thanks,
Clinton.
 Posted: Monday Jun 6th, 2011 10:53 am
cgiltrow
I see the rs232 document has been updated with the CM command.  Thanks.
Is there anyway I can get the menu item text through the protocol?
Cheers,
Clinton.
 Posted: Monday Jun 6th, 2011 12:06 pm
The menu text cannot be obtained from Comfort as they are not stored in Comfort, only in Comfigurator
 Posted: Tuesday Jun 7th, 2011 03:30 am
UCM 6.002 can be used to upgrade its own firmware so that you do not need another UCM with a programming cable in future
See instructions at http://www.comfortforums.com/forum4/2283.html
 Posted: Sunday Jun 12th, 2011 07:37 am
Just something I found with the new firmware, the DT command doesn't return the current Date & Time as stated by the Serial protocol documentation.
DT without any parameters will cause the UCM to send the current date and time in a DT report
 Posted: Sunday Jun 12th, 2011 07:47 am
You are right, that seems to be a bug that crept in due to the changes in handling date and time recently. The engineers will look at it in the backroom
 Posted: Monday Jun 13th, 2011 12:34 pm
schford
I wouldnt mind I am near Windsor - where abouts are you?
Stuart
 Posted: Monday Jun 13th, 2011 01:23 pm
bs85
Stuart
Stuart I have sent you a PM
 Posted: Thursday Jun 16th, 2011 01:17 pm
lbsltd
Please send the UCM/Ethernet with a note to us for a free upgrade.
Address is as follows.
Laser Business Systems Ltd.
16 Garthland Drive
Barnet
Hertfordshire EN5 3BB
Regards,
Kwong Li
li@laser.com
http://www.laser.com
http://www.cbus-shop.com
 Posted: Friday Jun 17th, 2011 10:28 pm
Hey,
I just want to say thank you Cytech for version 6.xxx of the UCM firmware.  It makes updating firmware a simple and quick task.
I can finally see the day ahead when I'll be able to upgrade all of my UCM types and the mainboard firmware without having to take remove the panel cover for access and fiddle with programming cables. Hoorah!.  My cover has been off so many times in the last couple of years, the 4 screws start to unscrew themselves whenever the screwdriver is within ten feet of their slots; they are that loose!  :D
Well done on a great new feature.
 Posted: Saturday Jun 18th, 2011 03:21 am
13th Post
That day is coming soon
 Posted: Wednesday Jul 13th, 2011 09:46 am
14th Post
Yes If you reply to this e-mail ill send you our details..
 Posted: Thursday Aug 18th, 2011 04:12 pm
15th Post
palmlodge
Is this applicable to the Universal UCM - seems to imply no in this document. But I see no separate folder to the U-UCM.
Thnx
 Posted: Thursday Aug 18th, 2011 04:22 pm
16th Post
bs85
Thnx
Here is the Universal UCM Firmware on page 2 of the firmware page
http://www.cytech.biz/universal_ucm_firmware.html?category_id=101
 Posted: Friday Aug 19th, 2011 04:30 pm
17th Post
Universal UCM is an "external" UCM which can be upgraded by the Comfort bus if its firmware is 6.xxx
 Current time is 03:37 am
