UCM05 Firmware 5.174 to 5.192
 Posted: Wednesday Oct 7th, 2009 03:39 pm
Download UCM05 firmware upgrades from here
Version 5.192 (28 July 2009)
  • Implemented query S? for alarm state 0 to 3. Requires Comfort 5.173
  • If counter command from Comfort does not change the value of the counter, dont send CT to the UCM
  • Report BYzzss when zone zz is bypassed or unbypassed and B? query
  • Improved communications with Comfort immediately after UCM reset so that the initial commands are not missed.
  • Added F! Set Flag and F? Query and FL report commands Requires Comfort firmware 5.173
Bugs
  • No reply to C? And s?
  • When Comfort broadcasts counter change >= 128 to 255, this may affect the state of other reported Comfort conditions eg high zone numbers
Version 5.183 (11 May 2009)
  • Write to Comfort from Comfigurator - if number of bytes received from Comfort is less than requested by PC, dont send the extra no-value bytes to the PC
  • RS232/Ethernet/USB Transmit Buffer size increased from 240 to 500 bytes
  • Report Sensor state S?NN to UCM
  • TM01 mode works with isolated RS485 module
  • Fixed bug No reply to C?
  • Implemented set sensor command s!nnvv
  • TP query works to get Time programj status
  • fixed BUG Broadcast to modules type was rejected affects SEM, UCM, KT03
  • FIXED bug AM, ER, AR, KL, DB messages sent rubbish characters
  • Doorbell command Dbxx implemented where xx is ID
Bugs
  • Bypass report BY and B? does not work
  • FL reported even when not logged in
Version 5.178 (29 Jan 2009)
  1. Fixed Bug s? Command does not work
  2. Fixed BUG command WD to UCM EEPROM address 0800 hex does not work if EEPROM is 24C256, (for UCM/KNX)
Bugs
UCM 5.174 (24 November 2008)
  • Implemented WD write to other UCM EEPROM, RD Read from other UCM EEPROM, WE conformatiom of write to EEPROM, u? Query ID product type, version and revision. Needed for UCM/HDL and other future external UCMs
  • Improved Firmware download
  • Upload Button on UCM will toggle BUSY1 LED when it is receiving date from Comfort.
  • Download Button on UCM will toggle BUSY2 LED when it is sending data to Comfort
  • Improved Upload, Download and Copy button reliability and speed
  • Confirmed problem with Upload/download butons on UCM If Master/Copy shunts are switched, power must be off and ON, Reset will NOT work
  • Firmware download - of any  rejection of firmware download occurs, UCM sends NA01, NA02, NA03, NA04 for different terminating conditions to find out why UD command sometimes fails
  • Firmware Programming improved, can recover from error
  • Implemented u? Query firmware command to support the SCAN for Modules function. Requires Comfort 5.154, SEM 5.156. KP05 1.010, external UCM  5.168
Bugs
 Current time is 03:24 am
