Version 4.234 (31 March 2006)- Fixed "off" word announced wrongly
- KP04 Event log is not silent, will be announced
- In Alarm history pressing 0 will disarm system
- Report to event log when gsm has no network and is subsequently restored. GSM TROUBLE is announced as "Communications Failure" as vocabulary version is not changed. GSM TROUBLE RESTORE is announced as "Communications Failure Restore" as vocabulary is not changed
- Fixed issue when comms fail to GSM ID, GSM Network status is not restored when comms is restored.
- Comms Fail timer increased
- Fixed issue did not restore rs485 comms fail to event log if any UCM ID - change so that only UCM ID =1 restore is not reported.
Known Issues- Bypass, unbypass zones are NOT reported to CMS, event log and UCM when zones are autobypased during force-arming and auto-unbypassed during disarm
- Action 199 (Say Words) does not work
Version 4.233 (30 November 05)- Minor improvement in reporting slave zones
Version 4.230 (10 October 2005)- Added Branch actions
- Added Action 112 for extended sensitivity action (Pagewatch)
- DA for Copy counter 198 added
Known Issues- Off word behaviour - When zone is open and closed and OFF WORD is announced, when zone open again OFF word is announced again
- UCM/GSM when RS485 comms fail, Comfort indicates network failed but when Comms restoted, network not restored so SMS does not work.
- Did not restore rs485 comms fail to event log if any UCM ID
Version 4.229 27 Sept 2005
- Fixed UCM/Gsm problem - when dial out by GSM and call is answered, but user hangs up without acknowledgement, the GSM redials endlessly
- Fixed - when dial out to 2 phone numbers and GSM is installed, the 2nd call will dial by GSM and not fixed line.
- Fixed occasional X10 lockup problem. This occurs rarely when there is an X10 transmission OR Infrared transmission which happens at the same time as an X10 signal is being received. Only occurs when the x10 transmit or IR transmit is about to begin when the X10 signal is received. When this happens the X10, outputs and and IR signals are stuck and no new commands can be sent until system reset. Also implemented a 6 second time out to flush the IR, X10 and Output command buffer of an IR or X10 command is not completed
- Fixed - when there is a reminder action on DP, the KP speaker is sometimes turned on.
- Supports UCM command B? For zone bypass query. BY bypass report also implemented. Requires UCM 5.76
- Report entry/exit timer value in EX message to UCM, EX NNSS
Version 4.228 29 June 2005
- When system dials to a Voice Phone, the user name/number or device ID will be announced with the alarm type. Before only zones will be announced for zone based alarms
A4.227 3 May 2005
- Fixed - display of zone name on KP04 : when No of SEM > no of DP, and the zone is on SEM, the SEM zone is not displayed on KP
A4.226 29 March 2005
- Increase delay for detection of phone offhook after Ringer signal caused by Door Station so that a false offhook signal is not detected causing the ringing to stop.
- For GSM if caller id does not verify with programmed phones, send verify reply with Index=0
- When abort arming, the Mode change report for Security off will be broadcast so the LCD Keypad will see "Security Off". Duress will also report Security off Minimun version to support KP04
- Fixed - Could not bypass zone in certain modes when there is a 24 hour zone type in the system
- Fixed false "zone 60 trouble" reported if SEM1 and SEM2 is connected but not enabled (No of SEMs) but Zone 60 zone type is set to nonzero.
- Offhook detection is enabled 800 ms after the end a ring signal (increased from 600 ms). This is to prevent false offhook detection preventing the system from answering calls reported by some customers depending on the phone
A4.225 (2 December 2004)
- Fixed in Ultra - Vac OFF Response and for next day are at wrong times.
- Fixed in Ultra - counter responses > 127 are not activated
O 4.222 (25 August 2004)
- Fixed issue from 4.207 for rev E6 PCB - when door station button is pressed for DP to KP intercom the voice cannot be heard on either side, until the keypad menu is entered and exited with "Thank You Goodbye".
- GSM enabled for Outside (PRO)
- Fixed bug for Outside X10 receive function from 4.221 - any housecode besides programmed housecode could receive unitcode and activate received responses, eg if Housecode = C, a1l housecode ON could activate X10 receive code for A
- X10 Status feedback (fbtype=6) for control menu enabled for Outside
A 4.221 (5 August 2004) - Ultra Release
- Fixed - Activation of Zone 64 caused announcement "zone 0 trouble" and in Event Log
- Fixed Event log issue for Entry delay alarm, Siren Trouble and Local Tamper trouble
- Fixed in reporting Restore of trouble alarms for dialout ands event log. Before, the wrong alarm type may be reported as restored
- Fixed issue where if the system is reset when it is armed, zones which are open will be bypassed and cannot be restored. The system had to be disarmed and reset
- Pro/ULTRA - Improvements in Receive X10 operation. Multiple (up to 8) X10 housecode/unit codes can be received followed by function codes, e.g. ON, OFF which will activate the X10 Responses for the received house/unit codes. e.g. A1, B1, C10, B ON will turn on B1, C ON will turn on C10, A OFF will turn off A1.
- For ULTRA, 256 X10 Housecodes can be received, up from 1 for PRO)
- Implemented X10 Status announcement in control menu. Feedback Type for X10 is 6
- Alarm History is now part of the Event Log and not saved in a separate memory area. The Alarm History will play from the last time the system was armed like before, but will announce events from the event log. Thus the limit of 20 alarm events is removed
- Improved accuracy of the announcement of trouble alarms in voice menu when there are several trouble alarms active and being restored
- ST State request command from UCM can be used to check states of internal tasks for troubleshooting purposes
- Added support for GSM module. Requires Vocab E6. PCB Rev E6 is needed to support GSM Module
- If DSP U6 is faulty, operation of alarm still continues without any DSP functions, i.e. dialing, voice, DTMF detection. Before this, operation continues if U7 Flash containing vocabulary is corrupted, allowing dialout and alarm to work
- PS00 is reported by UCM when system is armed
- UCM DT command will reply with date and time
Known Issues
- From 4.207 for rev E6 PCB - when door station button is pressed for DP to KP intercom the voice cannot be heard on either side, until the keypad menu is entered and exited with "Thank You Goodbye". The keypad menu is entered before any intercom, then everything will be normal.
Version 4.208 (22 July 2004)
- Fixed - If Delay After CMS for other phones is set to 1 second, the value is read as 256 seconds, so other phones will be called after 256 seconds
- Fixed - DA command for Action 197 SKIP did not work for UCM command
Known Issues
- For Trouble alarm restore to pager, the alarm type reported is is the current alarm, not the alarm which is being restored. Wrong alarm may report restored when there are several incidental alarms active.
- When system is armed, engineer signin is disabled but PS00 is not sent - from 20/3/03
- If system reset while armed, system will force-arm and bypass open zones. Bypasssed zone cannot be restored or triggered after reset.
- When system is in Duress, engineer code disarms the system, & report user = 00 in event log
- Entry Delay Alarm, Local tamper trouble and siren tamper trouble eventlog issue
Version 4.207 (15 April 2004)
- Must be used with PCB Rev E6 which caters for GSM connector. Older PCB Rev E5 and earlier can also use this firmware. If older firmware is used with PCB Rev E6, local phone access will not work - DTMF will not be detected
- Fixed bug in Common Mailbox: Users 9 to 16 are be able to access the common mailbox
Bugs
- Intruder alarm after Entry Delay, Local tamper and siren tamper do not go into eventlog.
- For DA action 197, SKIP in action 197 did not work
Version 4.204 (27 October 2003)
- Enhancements to work with CTOUCH special keypad keys
- Fixed issue where doorbell rings, but keypad F key is pressed to exit without going into the Door station menu, at the next reminder message time, the reminder does not time out, and keeps ringing the phone and chiming keypad without time-out
Known Issues
- Entry Delay alarm, Local tamper and siren tamper - eventlog issue
- Users 9 to 16 without mailbox can access 1 to 8 messages
- User 9 to 16 sign in will announce number of names and new messages for Mailbox 1 to 8 in the main menu, and can access common mailbox messages
- For Trouble alarm restore to pager, the alarm type reported is is the current alarm, not the alarm which is being restored. Wrong alarm may report restored when there are several incidental alarms active. Fixed 4.209
- When system is armed, eng signin is disabled but PS00 is not sent
