Posted: Saturday Aug 13th, 2016 12:17 pm |
Posts: | 5493 |
Changes for Firmware 7.112
Known Issues- Execute Response in Comfigurator (DA) with multiple actions - security alarm actions eg bypass, Do Alarm cause subsequent actions do not work. eg Bypass zone 1, bypass zone 2, output 1 on Only Bypass zone 1 will work. However the Response executed by Comfort events will work
- Bypass action has other problem of clearing a memory bit
- After Upgrading firmware to 7.113, some unused zones (Null zone Type) may have Partition 3 setting, and this causes the system to be unable to arm, and causes the keypads to give a strange beeping sound. UCM and Keypad is unable to log in until the arming aborts after 5 minutes.
- Actions Add counter, Add counter give wrong answer from 7.039
- Vocabulary Upgrade does not work, causes vocabulary to be erased. This has been fixed in version 7.113
- CM9000- OPT firmware bug Clear all outputs action 8 does not work
- Do Action 190 serial command DABE does not do the actions following action 190 correctly. The 1st action is continually repeated
- Action 73, 16 Get keypadId/ If Keypad ID does not work
Bugs Fixed- Fixed bug if incoming time message has no seconds, the minutes change is not updated.
- Fixed occasional problem where KP04 "wrong text press *1" cannot work, still get wrong text press *1" but after comfort reset this does not happen. Fixed the problem no more wrong text press *1. LCD text is actually good but wrong status shown in Keypad
- Fixed Bug for sentence table upgrade failure
- Fixed BUG when entry door causes intruder alarm due to no sign in, the Entry zone restore message is not sent to SMS or CMS if the zone response or Alarm response loads zones and if any other zones are triggered between the entry door open and the intruder alarm.
- Fixed bug from 7.099 - KNX and CBUS mapped to Comfort time could not change time in Comfort.
- Fixed BUG from 7.077 when controlling zwave from the control menu, smart polling did not work correctly. This has no effect on zwave control
- Program entry warning time actually programmed entry time BUG from 7.077
PartitionsKNX/CBUS/UCM- Set maximum zone nased on last programmed nonzero Zone Type for Z?, KNX and C-Bus to report zones at reset, instead of all 96 zones or according to no of slaves. This takes care of virtual zones which exist outside installed slaves.
Control Menu- If Feedback Type = counter, flag or output, and if action key 0 and 1 have No words, then action key 0 and 1 automatically control the counter, flag or output, eg Flag and output off/on, counter = 00 or FF
LEM03- Automatically detect LEM03 and write to EEPROM LEM03 checkbox location
Actions- Added action 158: 158, counter number, 0 = clear, 1 = set, 2 = toggle
- Added Action 73 param 28 = partition for armed/ disarmed
- Added Action 80 set partition for arming/disarming
Miscellaneous- No of Non-detector Alarms increased from 28 to 31 for future use by Comfort
- If arm to same mode, reply with security mode instead of no reply MDss
- Support control messages to HIO
- Support EL command for EOL shunts settings for Comfort and SEM v7.100 +
Posted: Saturday Aug 13th, 2016 04:30 pm |
cc_uk
Posts: | 66 |
I had a problem uploading the kate39.bin file after this - have posted details in the Vocabulary section on this forum.
Posted: Tuesday Aug 16th, 2016 08:29 am |
Posts: | 5493 |
The vocabulary upgrade problem in 7.112 (Beta) has been fixed in ULT 7.113 (Beta)
If you have 7.112 please upgrade
Known Issues
- For Partitions, Eng Menu 4,5 say Keypad area announcement gives the wrong partition number
Posted: Sunday Sep 11th, 2016 06:58 am |
Posts: | 5493 |
Firmware 7.113 is released. No significant difference from 7.112 except for the bug fix
- Partition keypad disarm does not off siren when disarm partition if there is a trouble alarm, until the code is entered 2 times
Posted: Wednesday Nov 16th, 2016 04:38 pm |
Posts: | 5493 |
There is a bug in Comfort firmware 7.113
if the firmware is upgraded from an older version some of the higher numbered unused zones may have nonzero partitions due to unused memory locations now having a meaning
The effect of this is it causes a problem while arming if zones are open. The announcement and beeping on the keypads is interrupted and continuous and the system cannot arm. The keypad and Comfigurator cannot sign in until after 5 minutes, the Arming abort Time.
The work-around if the system gets into this state is to wait for 5 minutes when the arming aborts. Then check the zones settings in Comfigurator make sure that all zones do not have Partititions>0 (provided this system does not use Partitions), and do a write to Comfort
A new firmware will be released shortly
