Comfort Firmware 7.099
 Posted: Wednesday Apr 27th, 2016 05:25 pm
Comfort Firmware 7.099 (changes from 7.093)
Known Bugs
  1. Execute Response in Comfigurator (DA) with multiple actions - security alarm actions eg bypass, Do Alarm cause subsequent actions do not work. eg Bypass zone 1, bypass zone 2, output 1 on Only Bypass zone 1 will work. However the Response executed by Comfort events will work
  2. Actions Add counter, Add counter give wrong answer from 7.039
  3. Time change from KNX and Cbus group address are ignored
  4. CM9000- OPT firmware bug Clear all outputs action 8 does not work
  5. Do Action 190 serial command DABE does not do the actions following action 190 correctly. The 1st action is continually repeated
  6. Action 73, 16 Get  keypadId/ If Keypad ID does not work
Bug Fixes
  1. When several Keypads were reset together, sometimes one of them would show "Wrong text - press *1 to sync"
  2. Fixed occasional problem where the zone restore was not sent to SMS or CMS after the same zone caused alarm and sent SMS or CMS alarm.
  3. Fixed old BUG where ETH03 is used to update date and time in Comfort from Internet time. During Daylight saving time, adjusted time from 12AM to 12:59 AM was set back to 11 PM to 11:59 PM. The time is correct from 1 AM onwards.
Improvements
  1. When a zone which caused alarm is restored, record zone restore to event log. Before only zone trouble restore is recorded in event log.
 Current time is 11:54 am
