Comfort 7.090 to 7.093
 Posted: Saturday Nov 7th, 2015 07:33 am
Firmware 7.090
Changes from 7.078 (includes changes for 7.083 Beta)
Known Issues
  1. Execute Response in Comfigurator (DA) with multiple actions - security alarm actions eg bypass, Do Alarm cause subsequent actions do not work. eg Bypass zone 1, bypass zone 2, output 1 on Only Bypass zone 1 will work. However the Response executed by Comfort events will work
  2. Actions Add counter, Add counter give wrong answer from 7.039
  3. During Daylight saving, using ETH03 to update Comfort time, the time from 12 AM to 1 AM is behind by 1 hour, ie not moveed forward for daylight saving, but is correct from 1 AM each day.
  4. u?00 does not discover unpolled modules, and serial numbers may not be correct.
  5. CM9000- OPT firmware bug Clear all outputs action 8 does not work
  6. Do Action 190 serial command DABE does not do the actions following action 190 correctly. The 1st action is continually repeated
  7. Action 73, 16 Get  keypadId/ If Keypad ID does not work
Bugs Fixed
  • FIX BUG - if Disable Line Cut box is not checked and Misc alarm Line Cut Alarm = 0, 1 alert zone will cause intruder alarm.
  • Fix BUG Logic engine slider cannot work send CMGGCCxx problem
  • Fix Bug from 27/12/14 in alarm state, turned on broadcast for keypads and this remains enabled even after disarm
  • Fixed bug from 7.077.  v! did not work unless full vocab transfer is done. sentence upgrade alone without vocab upgrade failed
  • Fixed Bug for Action 155  - Send Custom SMS message # parameter inst of phone # for event log. added another event for custom message #
  • Fixed bug when event log goes to 1st or last event, it did not announce the event menu, it used to go back to announce the same event
  • Fixed bug gsm id was always 0 for a? Reply
Event Log
  • Added event type for Send SMS Custom message # for action 155 for gsm4. Event will announce number and "new message for"
  • Event Log announcements start from last event and play backwards in time. But Read event log in Comfigurator still is from 1st to last.
  • Event log when press keys 5,6,7,8  do not announce "wrong code"  immediately announce the event menu
  • Alarm history go to last event not at alarm history pointer, now the same as event log.
  • Event log events battery warning, Phone Line trouble, system reset , Voice Fail etc all will have parameter 1 instead of a random number
UCM Commands
  • AMFF will not be reported  when the zone alarm has no Nondetector alarm eg Alert/Perimeter
  • Implement  reply to reminder query RM
  • Allow module scanning for ID7 (Sensor) and 8 (HIO)
  • If Nondetector alarm for Phone trouble = 0, AM04 (Phone trouble Non detector alarm) will not be reported
New Features
  • Duress code only need to enter 1 time, instead of 2 times, in order to avoid problems
  • Action 86 Check Timer Action return 0 if not running, and returns the Remaining Timer value in seconds if timer is running.  eg DA5601 (Do action 86 Check Timer 01). Reply RA8001 means Timer remaining time is  128 +256 = 384 seconds. This allows checking of timer to be implemented in Comfigurator.
  • Implemented Execute Time Program Response command TPnn02 (nn = time program number in hex). This allows a command to execute the Response for the Time Program directly
  • If a zone changed to Off without being previously ON or Trouble state, then Off Response is not activated (applicable for rare instances)
  • Support Serial Number query for IRIO, TSM HIO and future modules
  • Support u?00  command to automatically reply u? for individual IDs as well as SN serial number replies. Modules that are not present will not reply. This shortens the time required to do a scan for modules. Requires Comfigurator 3.10.8
 Posted: Thursday Nov 19th, 2015 05:31 pm
Comfort Firmware 7.092
Bugs
  1. During Daylight saving, using ETH03 to update Comfort time, the time from 12 AM to 1 AM is behind by 1 hour, ie not moveed forward for daylight saving, but is correct from 1 AM each day.
  2. the u?00 command used in Module scanning from Comfigurator 3.10.9 sometimes causes the UCM/GSM4 to behave as a UCM/GSM ie the user names, zone names and control menu names are not sent in the SMS, reverting to numbers instead. This affects system with UCM/GSM4 only
  3. CM9000- OPT firmware bug Clear all outputs action 8 does not work
  4. Do Action 190 serial command DABE does not do the actions following action 190 correctly. The 1st action is continually repeated
  5. Action 73, 16 Get  keypadId/ If Keypad ID does not work
Changes
  1. Improved u?00 query one time for all modules and serial numbers for Module scan by Comfigurator. This feature requires Comfigurator 3.10.10
  2. If Comfort time changes by less than +/- 15 secs, it will not to  Eventl og or rs485 due to too frequent time updates in the event log
 Posted: Monday Dec 21st, 2015 04:08 pm
Comfort 7.093
Fixes bug in Comfort 7.092 where the u?00 module scanning command causes UCM/GSM4 to behave like UCM/GSM
Comfort firmware 7.093 has been released
 Current time is 04:13 pm
