ULT 7.055 (beta) can be downloaded from http://www.cytech.biz/comfort_ultra_firmware.html?category_id=101
This fixes a bug that scanning of Invalid IDs (via the u? command) did not give a valid reply.
It improves scanning of old models of Keypads and Door stations which did not recognise the u? scanning command. In previous versions, if the old keypads and DP03 are not polled by Comfort due to the number of Modules not including that ID, these old models were not detected by Comfigurator scan. You had to add the keypad or door station manually and write to Comfigurator. Once the models are polled, then the Scan by Comfigurator will detect these old models
With this firmware old models of Keypads and Door stations can be detected by scanning even if they are not polled
Known Issue - Extra keypads 9 to 15 may be detected after a scan using Comfigurator 3.8.7 to 3.8.8. This happens if the scan is done after initialisation. The workaround is to wait about 30 seconds and repeat the scan. Pleaese upgrade to ULT 7.057 which does not have this problem
