ULT 7.047 to / 7.050
 Posted: Friday Jan 10th, 2014 03:06 am
The firmware 7.047 beta changes are
Known Issues
  1. After updating Keypad LCD words using keys *1, Scanning of UCMs by Comfigurator will detect UCM #1 as HDL. This is an old bug
  2. RC01 Keypad buttons (0-9, *, #) cause the keypad to have a long beep, and are not able to work as keypad
  3. Sending SMS to Comfort with UCM/GSM will reply "Unknown command" if there is no control Menu Feedback, even though the  control is performed correctly
Bugs Fixed
  1. Night Time Flag did not work. Night Time flag is set by Sunset and Cleared by Sunrise according to the Sunrise/Sunset times for each city
New Features
  1. When system is being armed, the F key will cancel the arming, similar to the * key. Previously, the F key while arming produced a long beep
  2. New keypad keys supported in Comfort protocol. This is for support for new Wizcomfort software to be released
  3. User flags has been increased from 64 to 256 ie 0 to 255
Please download from http://www.cytech.biz/comfort_ultra_firmware.html?category_id=101 for those who are affected by the Night Time flag issue
 Posted: Saturday Jan 11th, 2014 06:08 am
This is an explanation of the assignment of user flags to Night Time flag
Iif you assign, eg Flag 64 to Night Time Flag, then the Night time flag state is copied to Flag 64. By checking Flag64 you can know if it is Night, ie after sunset and before sunrise as set in Sunrise/Sunset Time
the ccommand F?nn in Comfigurator Monitor IO also returns the state of the flag
eg
> F?40  (40 is 64 in hexadecimal)
< F?4001 means Flag 64 on
<F?4000 means Flag 64 off
At sunset, the UCM will report
<FL4001
ie Flag 64 =1
At sunrise
<FL4000
is flag 64 = 0
The next Comfigurator 3.8 will have a setting for this flag assignment
In the meantime, go to  Location 374  to assign a flag number to Night Flag
eg Location 374 = 64 assigns Flag 64 to Night Time flag
 Posted: Thursday Jan 16th, 2014 02:07 am
Ult 7.047 is now released
 Posted: Thursday Jan 16th, 2014 05:51 pm
Interestingly I had installed the beta version via local file upgrade but today in Comfigurator even though I had "7.047" (beta) already installed it still wanted me to upgrade to "7.047" again.    Are they different in some way as I'm sure I've never had this issue with Betas turning Live in the past?
 Posted: Friday Jan 17th, 2014 02:02 am
Comfigurator would not know if the installed version is beta or not
It should compare the firmware version  with the latest on the server
I have not encountered that. Check for updates said "ULT 7.047 is the latest"
 Posted: Friday Jan 17th, 2014 08:34 am
It definitely did it for sure.  After  starting Comfigurator and logging in I first upgraded my GSM4 firmware and the system rescanned as usual.  I then clicked on the "Controller" node and it listed:
  • Comfort Version = 7.047
  • Latest Version = 7.046
I did a Check for firmware updates and it brought up the dialog box asking me if i wanted to upgrade to 7.047! I downloaded and upgraded the firmware and all was well after that with future checks.
I don't particularly care as pretty minor but was strange observation so thought I'd feed back.
 Posted: Friday Jan 17th, 2014 08:37 am
strange
Perhaps the internet connection was bad at that time, and the correct version info was not obtained in Comfigurator?
 Posted: Wednesday Feb 26th, 2014 05:43 pm
Bug in Firmware 7.047
  1. RC01 Keypad buttons (0-9, *, #) cause the keypad to have a long beep, and are not able to work as keypad
 Posted: Tuesday Mar 4th, 2014 04:02 am
I have just been upgrading any units in our stores.
It does appear that by adding items at random and then scanning Comfigurator sometimes uses the values it already has its as though it does not refresh the screen.
So for example removing one UCM that had just been upgraded to 7.028 and then replacing it (same ID) with another older version UCM, comfigurator appeared to scan but still came up with 7.028.. I had to reset the main board and then re-scan
 Posted: Tuesday Mar 4th, 2014 05:27 pm
Firmware 7.050 (Released) has the following changes;
Bugs
Actions Add counter, Add counter give wrong answer from 7.039
Bugs Fixed
  1. Fixed Bug RC01 Keypad digits 0 to 9,#, * causes long beep on keypad
New Features
  1. Keypad Panic and Keypad fire will show in the Event Log with RS485 ID. Before,  keypad fire and panic in event log had no id
  2. Timer action if timer value is 0, then timer count is taken from Last Action Value so the timer count can be loaded from a parameter like a counter
  3. Added  Play new, Play saved and erase saved messages for user mode
 Posted: Tuesday Apr 22nd, 2014 05:22 pm
srooks
  1. Timer action if timer value is 0, then timer count is taken from Last Action Value so the timer count can be loaded from a parameter like a counter
What's the best way to convert a KT03 slider value (say with a minute scale) into a seconds value for a timer, using this new feature?
Thx,
 Posted: Tuesday Apr 22nd, 2014 06:19 pm
A KT03 slider is mapped to a Counter
so you can program as follows, assuming counter 2
Get Counter Counter002
Do Response XXX After 0 Seconds Using Timer01
This will take the value from counter 2 which came from the slider and use it as the delay before the Response XXX
 Posted: Wednesday Apr 23rd, 2014 12:45 am
13th Post
srooks
What about scaling. What's the best way of converting a slider with a range of 1-10 into seconds (60 - 600)? A KT03 slider can only have values of 0 to 255.
Thanks!
 Posted: Wednesday Apr 23rd, 2014 12:30 pm
14th Post
You can use the Multiply action
eg
Multiply Immediate 60
Set Counter002
Do Responsex After 0 Seconds Using Timer01
counters have range of up to 65535
 Current time is 12:02 pm
