Firmware upgrade for Comfort II SPC?
 Rating:  Rating
 Posted: Monday Oct 14th, 2013 11:51 am
nbexiga
I have a Comfort II SPC . I'm from portugal. Current my version of firmware is 6.011 file system 30, vocabulary 11, UCM Type 10 , UCM Version 6.008
I want to know if there is any update available for my central.
Many thanks
Nuno
 Posted: Monday Oct 14th, 2013 12:56 pm
SPC Firmware currently is at 7.032
UCM Firmware is 7.028
You can automatically upgrade any Comfort or UCM, KP06 or KT03 firmware using Comfigurator 3.7.6 when you are connected to the Internet
Do Scan for all modules, then the current and latest firmware will be shown as below
To Upgrade to the latest firmware right click on the module and select "Check for firmware Updates"
The firmware will be upgraded from the server
You will be asked to press F0 on the keypad
Please see the instructions on Upgrading firmware on the forum
http://www.comfortforums.com/forum92/3400.html
You should upgrade your UCM to the lalest firmware v7 before your comfort SPC
To avoid missing any announcements that may be important to you, I suggest to go to  the Forum Menu > My Account > Watched Forums and check the forums that you want tp watch. The posts that you select will be forwarded to you either as daily digest or individual emails as you choose
 Posted: Monday Oct 14th, 2013 01:29 pm
nbexiga
Thanks for your prompness on this.
Ok,
I have to to the update then.
One more question, if i upgrade the UCM and the Comfort and the UCM to the latest version, will i loose the vocab and the settings from the system including the sentences?
How can i backup that inforamtion if i don't have the file of vocab and the sentences?
The vendor did not give to me the file that files, only the files of the cclx..
 Posted: Monday Oct 14th, 2013 01:51 pm
Upgrading firmware should not affect the voice or sentences
If you have any problem let us know
 Posted: Monday Oct 14th, 2013 02:02 pm
nbexiga
ok, many thanks for the info.
when i arrive home i'll do 1st the UCM upgrade and then the Comfort , and feed back you.
 Posted: Monday Oct 14th, 2013 07:48 pm
nbexiga
HI
I did succesefully the upgrade on Comfort and on UCM, but when i do the scan for all modules, it appear the error that is in the picture.
After the error appear, i cannot do anything more, the error is allways appearing.
And how can i update the RIO firmware and the keypad? because it appear that i need another version to update from web (image attached with the versions)
I alredy removed and installed cytech software.
Attachment: System Info.JPG (Downloaded 58 times)
 Posted: Monday Oct 14th, 2013 07:55 pm
nbexiga
Error Scan Modules
Attachment: Error Scan Modules.JPG (Downloaded 58 times)
 Posted: Monday Oct 14th, 2013 07:56 pm
nbexiga
RIO Info
Attachment: RioInfo.JPG (Downloaded 57 times)
 Posted: Tuesday Oct 15th, 2013 12:54 am
Can you do the scan and in Monitor I/O do Copy to Clipboard and send the whole contents
Are you using Comfigurator 3.7.6?
RIO and SCS, KP03, KP044, KP05, DP cannot be upgraded by this method
 Posted: Tuesday Oct 15th, 2013 10:59 pm
nbexiga
I've just made some tests after i arrive home and i noticed that i don't have some things working besides that error..
The output that was working that was the curtains up and down, is not working. only works on the physical press button. and other issues that i explain better with logs and .jpg atached in a document that i did.
please find out the .docx in the post with the config files and I/O monitor.
i send to you a private message with the password of the zip file.
i would be really appreciated if you can help me solving this.
many thanks
regards
Nuno
Attachment: Cytech Nuno Bexiga.zip (Downloaded 3 times)
 Posted: Wednesday Oct 16th, 2013 06:39 pm
nbexiga
Just to update you with the status of the issue that i am having:
I've just tested one thing and i rollback for the older version of Comfort firmware 6.011, i let the UCM in the current version (7.028) and the responses and outputs are working fine now.
The application errors that appear are still appearing
Does my comfort don't allow to be upgraded to the new firmware version? Or if is possible how can i do that?
Attachment: Rollback.JPG (Downloaded 45 times)
 Posted: Saturday Nov 2nd, 2013 01:05 pm
This is to update that the cause of the exception was found to be due to an invalid serial number generated after upgrading to the new firmware 7.040
This issue will be fixed in the next firmware and also Comfigurator will not generate the exception
 Posted: Monday Nov 4th, 2013 12:24 pm
13th Post
nbexiga
one more time tahnks for your help on this .
you were very promptness and always with a solution.
Many thanks!
 Current time is 04:40 pm
