Comfort Firmware 7.026 - 7.029
 Posted: Tuesday Apr 16th, 2013 03:57 am
Firmware 7.026
Bug Fixes
  1. If Comfort voice is corrupted  is bad, v? Will report v?FFFF.... Instead of no reply. That caused KP04 not to get reply to query for Vocab version causing KP04 to repeatedly query comfort  Fixed Bug from 7.009
  2. Fixed BUG old SEM and SCS which do not support u? Scan command will be reported as u?000000FF if no of modules is less than  its own id so Comfigurator scan nodules knows that it is present
Known Bugs
  1. Reminder Enable function does not work for Reminder Numbers 9 to 16. Reminder Enables for 9 to 16 are the same as Reminder 1 to 8. This affects Scheduled Reminders only.
  2. Action 8 - Reset All Outputs does not work. Bug from 7.007
  3. for SPC abdOPT action 74, resp  bug does not  return to do next action from 7.010
  4. Action 149,0, constant add to last value did not work from 6/2/12
    Sentence upgrade after vocab upgrade fails with error 29 dtad
  5. reminders 9 to 16 enables are the same as reminder 1 to 8  Tiime Program enables 9 to 16 are same as Time prog 1 to 8 for OPT and SPC from 6.017
  6. UCM u? Scan for all KP will reply KL
  7. action 8 reset outputs does not work from 7.007
    when UCM lost comms but not lost power (remove KAKB not 12V) and is connected again so id  comms is restored,  module does not report 7DH (not reset) so u? reports FFFFFF and comfigurator has status still as "not found" for the module that has recovered.
 Posted: Sunday May 12th, 2013 08:24 am
Firmware 7.027
  1. Output command ON or OFF  is ignored if the output state is unchanged
  2. Fixed BUG action 8 reset_outputs failed (from 7.007)
Bugs
  2. A Flashing output on a Slave cannot be turned off by an Output On or off command. Only Reset all outputs command can reset the output. Outputs 1 to 16 on the Main Comfort board are not affected by this bug
  3. Pressing buttons on SCS causes the corresponding LED (output) to flash until Comfort sends a command to switch it on or off (using Response). Due to the comparison of output states introduced in 7.027, the LED may remain in the flashing state.
Please upgrade firmware from Comfigurator 3.6.x Modules Tab right click and check for updates
 Posted: Thursday May 16th, 2013 11:02 pm
gaynorc
I upgraded firmware 6.020 to 7.027 today.
Subsequently after arming the system to away mode, and then disarming the system, I encountered a problem with a response which had previously been working fine.
On entry to the house while in "away mode" a zone response (the entry route) switches an output to "flash" (connected to a buzzer). When the system is disarmed, the Miscellaneous Event "Security Off Response" has a response which switches that output to "off". That worked with 6.020. With 7.027 the output remains in "flash" and is not switched off.
As a temporary work around I have included in the Miscellaneous Event "Security Off Response" response an "all outputs off", and that silences the buzzer. Obviously this is not a solution. I wonder has this something to do with the new feature "Output command ON or OFF is ignored if the output state is unchanged" when the command has previousy been "Flash"?
 Posted: Friday May 17th, 2013 04:09 am
We cannot duplicate this problem in 7.027
when an output is flashing, an on or off command will stop the flashing
Can you send the cclx file to support@cytech.biz so we can check
 Posted: Friday May 17th, 2013 07:47 am
gaynorc
File now sent as requested
 Posted: Friday May 17th, 2013 12:55 pm
Thanks for the file.  We have confirmed there is a bug in 7.027 which prevents the Flashing output on the Slave from being turned off except by All Outputs off.
Flashing outputs on Comfort outputs 1 to 16 behave correctly so perhaps you can use one of these outputs as workaround
A new version will fix that bug
 Posted: Monday May 20th, 2013 05:19 am
ULT7.028 Beta is available from http://www.cytech.biz/product_details.php?item_id=210
This fixes the bug found by gaynorc that a Flashing output on a Slave cannot be switched off except by action 8 ( reset all outputs)
 Posted: Tuesday Jul 16th, 2013 12:28 pm
Firmware 7.028 Bug
  1. Pressing buttons on SCS causes the corresponding LED (output) to flash until Comfort sends a command to switch it on or off (using Response). Due to the comparison of output states introduced in 7.027, the LED may remain in the flashing state.
 Posted: Monday Jul 22nd, 2013 08:44 am
Firmware 7.029
This fixes the bug from 7.027 affecting SCS.
When a button is pressed on SCS causing the corresponding LED to flash, sending a command to switch off the LED will not stop the flashing LED
Please upgrade firmware using Comfigurator
 Posted: Saturday Jul 27th, 2013 04:19 am
A problem with Reminder Messages bug has been discovered which affects Firmware 7.017 to 7.031
Reminder Messages 9 to 16 Enable settings do not work
Instead the Enable settings for Reminders 1 to 8 are used
eg Reminder 9 uses the Enable setting for Reminder 1, Reminder 10 uses Remiinder 2 etc
Attachment: reminders.jpg (Downloaded 28 times)
 Current time is 11:38 am
