Posted: Friday Feb 15th, 2013 04:21 am |
Comfort Firmware 7.013 Beta has the following changes;
- Scan for modules will report modules that are not currently polled by Comfort. The u? Reply has been extended to u?nnTTVVRRFF where nn = id of module, TT = Product Type, VV = Firmware Version, RR = firmware revision, FF = 00 for ID good and FF for ID bad or not polled. Module that does not reply will have a report u?nnFFFFFFFF.
- Added action code Get Parameter 73,30 = Get Last Security Mode. Can be used to check what was the last security mode which the system was armed to.
- Added Action 120 Compare sensor compare inputvalue against sensor.
- Added action 153 load user value 2 bytes
- Added 2 byte Conditional branch actions Action 184 = Branch if equal, 185 = Branch if <>, 186 = Branch if >=, 187 = Branch if <, 188 = Exit if equal. The 2 byte values are signed ie can be positive or negative using two complement notation.
- Report counter broadcast 2 bytes when any counter changes
- Fixed BUG reset action 118 reset ID may not have worked
- Fixed BUG from ULT 7.009 - false Communications Failures may be sometimes reported
- Fixed BUG when trouble happens while in keypad menu and is restored before exit, KP06 and KT03 trouble remains and cannot clear. Bug Did not affect KP04 and KP03
- Logic Engine does not require Engineer sign in to upgrade firmware Does not affect other Comfort models
Known Bugs- Related to UCM/GSM. SMS messages do not show Zone Names correctly
- Scan for Modules where the module firmware does not support the scan command will report wrongly as module not found
- Copy Counters action does not work
- Say Words action does not work using a UCM Do action command
- if actions Bypass, Unbypass Key arm, Auto arm or Activate Door stations are followed by other actions in a Response, then the other actions are not done. Workaround is to place the above actions as the last action in a Response
- Actions 35 (Save Last Counter( 37 (Save Last Sensor), 121 (save Input value to sensor), 151 (Initialise Sensor) do not save the correct value
- Action 148 Multiply by Constant gives wrong result. But multiply by counter and Multiply by sensor do work
- Reminder Enable function does not work for Reminder Numbers 9 to 16. Reminder Enables for 9 to 16 are the same as Reminder 1 to 8. This affects Scheduled Reminders only.
- Vocab Upgrade fails during the sentence upgrade process with Error Code 29. If this happens, repeat Sentence Upgrade only, not the full Vocab Upgrade
Note New Action codes are not yet supported in Comfigurator 3.6.4
The firmware can be downloaded from http://www.cytech.biz/comfort_ultra_firmware.html?category_id=101
Posted: Friday Feb 15th, 2013 10:46 am |
ULT 7.014 fixes the bug for sending SMS without zone names (from ULT7.009)
Known Bugs- Scan for Modules where the module firmware does not support the scan command will report wrongly as module not found
- if actions Bypass, Unbypass, Key arm, Auto arm or Activate Door stations are followed by other actions in a Response, then the other actions are not done. Workaround is to place the above actions as the last action in a Response
Posted: Friday Feb 22nd, 2013 07:51 am |
Comfort Firmware ULT 7.015
Fixes bug where Scan for Modules where the module firmware does not support the scan command will report wrongly as module not found
Posted: Monday Feb 25th, 2013 06:44 am |
Bugs in 7.013 to 7.015- Copy Counters action does not work
- if actions Key arm, Auto arm or Activate Door stations are followed by other actions in a Response, then the other actions are not done. Workaround is to place the above actions as the last action in a Response
Posted: Wednesday Feb 27th, 2013 04:33 am |
A bug has been confirmed in Firmware 7.013 to 7.015 - if actions Key arm, Auto arm or Activate Door stations are followed by other actions in a Response, then the other actions are not done. Workaround is to place the above actions as the last action in a Response
Posted: Friday Mar 1st, 2013 05:57 am |
ULT 7.017 has been released
This fixes the bugs in 7.013 to 7.015- Copy Counters action didnot work
- Say Words action did not work using a UCM Do action command
- if actions Key arm, Auto arm or Activate Door stations are followed by other actions in a Response, then the other actions were not done.
Known Bugs- Actions 35 (Save Last Counter), 37 (Save Last Sensor), 121 (save Input value to sensor), 151 (Initialise Sensor) do not save the correct value
- Action Bypass and Unbypass cause following actions to be corrupted
Posted: Tuesday Mar 5th, 2013 12:33 pm |
ULT 7.021- Action 117 Change Entry Time action will apply only when the security if armed, so a zone open when security if off does not affect other zone entry times later.
- Fixed BUG from 7.013 actions 35, 37, 121, 151 did not work
- "Multiply by Constant" Action fixed Bug did not work from 7.006
- Multiply actions handle negative values for 2 byte values for Counter, Sensor and Constant.
- Convert F to C and Convert C to F actions handle negative temperature values in 2 bytes format
- During Entry Alert, a non-entry path zone activation causing a warning alarm will be recorded in the Event Log. Before the non-entry zone was not in the event log.
- Logic Engine can respond to a? , K? And Z? So it work with android and iphone app
Bugs- Action Bypass and Unbypass cause following actions to be corrupted
- The local phone is interrupted by the phone relay clicking
Posted: Thursday Mar 7th, 2013 06:29 am |
Bug found in 7.013 to 7.021
- Actions 75 Bypass and 76, Unbypass causes following actions in the Response to be corrupted
Posted: Thursday Mar 7th, 2013 08:17 am |
Howser
So, the work-around would be to downgrade to 6.028?Last edited on Thursday Mar 7th, 2013 08:19 am by Howser
Posted: Thursday Mar 7th, 2013 08:22 am |
We have found and fixed the problem, ULT 7.022 will be available soon
Posted: Saturday Mar 9th, 2013 08:38 pm |
mario.jr
With 7022 problem with the phone. Back to 7009 for me is more stable than later.
Posted: Sunday Mar 10th, 2013 01:34 am |
Exactly what problem are you getting with the phone?
Please describe so we can investigate
Also send the cclx file to support@cytech.biz
Posted: Sunday Mar 10th, 2013 09:42 pm |
mario.jr
I can not make calls. I'm always interrupted line. But I can receive calls.
Back in 7009 everything returns to normal.Last edited on Sunday Mar 10th, 2013 09:43 pm by mario.jr
Posted: Monday Mar 11th, 2013 04:31 am |
Can you send the ccllx file so that we cann confim if the problem is due to programming, to support@cytech.biz
If you are currently using 7.022 then upgrade again to 7.022 to confirm, wiith no other changes
thanks
Posted: Monday Mar 11th, 2013 09:36 am |
Posted: Thursday Mar 14th, 2013 05:47 am |
Bug has been confirmed for ULT 7.021 to 7.022
This will be fixed soon
Thanks for the feedback
Posted: Thursday Mar 14th, 2013 10:24 am |
17th Post |
