Firmware V7
 Posted: Tuesday Nov 27th, 2012 07:44 am
Will V6 firmware be upgrade-able to V7 by conventional means on all items of equipment?
V7 - Am I correct....... If we have a set up that is all V7 then the Comfort upgrade can be done by a 'simple' pull down menu saying 'upgrade system': presumably if you are on a PC with the relevant firmware or connection to the Ethernet then the whole process is done automatically !
Excellent
 Posted: Tuesday Nov 27th, 2012 10:58 am
V6 can be upgraded to V7 with the current methods like programming cable, Upgrade by Bus or direct connection
With Comfigurator 3.6 and v 7 firmware you can select any module to upgrade and right click to upgrade any more, as shown in the screenshot in the original post
 Posted: Wednesday Nov 28th, 2012 12:12 pm
When are v7 firmware likely to start being released?
 Posted: Wednesday Nov 28th, 2012 12:32 pm
Being tested some will be released in weeks
 Current time is 02:16 am
