Posted: Sunday Apr 8th, 2012 02:32 am |
Posts: | 1200 |
This is a pre-alert about the new firmware 6.020 which will be available soon
Update - ULT 6.020 is released http://www.cytech.biz/comfort_ultra_firmware.html
Bug Fixes- Fixed BUG from 6.011 when sign in "welcome" is not heard vmenu
Fixed bug upgrade sentence tab by itself did not work - Fixed intermittent problem for Firmware Upgrade by Comfort Bus.
- Fix BUG for handling GSM - if ucm ID was formerly GSM but another UCM type replaces it with the same ID in the system, it still tries to dial to GSM.
- Fix BUG Scan u? For SEM ID 4 and 5 did not work for 96 zones.
Improvements- UCM Download Button will first erase the whole U4 eeprom to improve speed of writing UCM U2 EPROM to Comfort. Needs UCM 6.019
- Disabled Siren Tamper alarm so shunt J4 SRNTMP has no effect. This alarm is not usually used and causes problems with the J4 shunt drops off.
- Improved Read/Write operations to U4 EEPROM whuch caused system to hang when read operations were interrupted
- Prevent Eeprom error at reset causing system to hang and escape Watchdog timer reset.
- Implemented Timer Runaway protection for Controller.
- Removed Adjust Daylight Saving Time Action 98 - not needed after Automatic daylight saving time change was implemented .
New Features
- Implemented Daily Time Adjustment location in seconds (Modules and Settings). Daily adjustment at 4 AM.
- New action Code Enable/Disable 152, user number 2-16, 1 for enable, 0 for disable, 2 for check. Save state when reset or system off. User 1 cannot be disabled. If eeprom location has user 1 disabled then all are enabled because this location may be set wrongly in eeprom before.
- Action 9 allows push button to be used to ring phones and keypad . If NO DPs then doorbell menu exits after say goodbye. When door station rings phones and entry door is opened, this automatically stops ringer without using action 26.
Known Bugs
- Assigning Output to Security > Status LED will cause KP Home/Armed LED to show the wrong status (from 5.220)
- Scheduled Reminder Messages do not work at the correct time (from 5.173)
- Reminder Enable function does not work for Reminder Numbers 9 to 16. Reminder Enables for 9 to 16 are the same as Reminder 1 to 8. This affects Scheduled Reminders only.
Importance
Important - for prevention of Comfort system hang due to system reset interrupting eeprom read/write
Posted: Monday Apr 30th, 2012 09:47 am |
Posted: Sunday Jul 8th, 2012 04:30 pm |
cgiltrow
I have just upgraded my comfort to this new version. After the upgrade the Home light on the keypad did not come on. Prior to the upgrade it was coming on.
I did arm. the Armed led did come on. I disarmed. The Armed led went off, but the Home (Off) led did not come on.
Your help will be appreciated.
Many thanks,
Clinton.Last edited on Sunday Jul 8th, 2012 04:39 pm by cgiltrow
Posted: Monday Jul 9th, 2012 02:04 am |
Posts: | 5493 |
Which keypad do you have, KP05., KP06 etc?
Is this repeatable?
If you arm again and disarm, the security off light still does not come on?
Posted: Monday Jul 9th, 2012 04:17 am |
Posted: Monday Jul 9th, 2012 05:18 am |
Actually ignore my last comment as a system reset on both of my systems ans the led is back again.
J
J
Posted: Monday Jul 9th, 2012 07:51 am |
cgiltrow
It is a KP04 keypad. I have tried arming and disarming and multiple reboots and reuploading the configuration, but none of these has worked. The home / off led has not come back on since the firmware upgrade.
Thanks.
Posted: Monday Jul 9th, 2012 09:25 am |
ULT 6.020 should not have this problem
Could you power off and on the Keypad? All the LEDs should blink momentarily
We suspect that the OFF LED may be faulty
Posted: Wednesday Jul 11th, 2012 03:27 pm |
cgiltrow
I powered the keypad off and on. All the lights did blink momentarily. Hence the Off LED is not faulty.
I tried resetting the system again, but the Off LED is stil not coming on.
Please assist.
Clinton.
Posted: Thursday Jul 12th, 2012 02:43 am |
Posts: | 5493 |
Can you confirm if this is due to the firmware by downlgrading to the 6.011 attached?
thanks
Attachment: ULT6_011.zip (Downloaded 3 times)
Posted: Thursday Jul 12th, 2012 05:19 pm |
cgiltrow
I downgraded to 6.011, but the Off LED is still not working.
I also tried upgrading to 6.020 again, but still not working.
Clinton.
Posted: Friday Jul 13th, 2012 01:18 am |
Posts: | 5493 |
It is probably a faulty Keypad
Do you have another one to compare in the same system?
Posted: Friday Jul 13th, 2012 09:26 am |
cgiltrow
I have a new KP06 I have been planning to deploy for a while.
Should I try that?
Posted: Friday Jul 13th, 2012 12:07 pm |
Posted: Sunday Jul 15th, 2012 01:53 pm |
cgiltrow
I have deployed the new KP06 and the Off LED is working.
However, the keypad has no sound. If I increase the volume to 99 and listen very closely I can hear the voice very softly. The voice is also muffled.
Please assist.
Clinton
PS: I tried resetting the system and the keypad, and I upgraded the keypad firmware from 6.001 to 6.003. None of these had any impact.
Posted: Monday Jul 16th, 2012 02:02 am |
17th Post |
Posts: | 5493 |
There should a Speaker on.off settng when you press and hold the * key
Check if it is off
Posted: Tuesday Jul 24th, 2012 04:28 pm |
18th Post |
cgiltrow
The sound problem panned to be a wiring issue. I had connected the voice to mic and visa versa on the new key.
That said, as much as the home/off LED is coming on, it now never goes off. So when I arm the system both the home/off and armed LEDs are on.
Assistance would be appreciated.
Posted: Wednesday Jul 25th, 2012 03:02 am |
19th Post |
You mean with the KP04, the OFF LED never turns on, and with KP06 the OFF led is permanently on, and this is the same Comfort?
Posted: Wednesday Jul 25th, 2012 07:57 am |
20th Post |
Current time is 03:42 pm | Page: 1 2 |
