Comfort ULTRA firmware 6.006
 Posted: Sunday Nov 6th, 2011 05:35 am
  1. Improved Firmware Upgrading via Comfort Bus to better handle error conditions and recovery and reply to comfigurator while if boot mode.
  2. Fixed in GSM - if initial GSM  network status is bad, eg no sim card when gsm is reset  then NO sms trouble  is reported in event log
  3. Remove SMS Trouble alarm as Nondetector alarm, as intermittent network conditions  may cause  many Trouble alarms to be reported.
  4. Extension to R! UCM command to handle parameter for response in future
  5. fixed bug on UCM query   RIO inputs - always replied off
  6. Fixed BUG for M! after remote arm, local arm also did not need exit
Known Issues
  1. Assigning Output to Security > Status LED will cause KP Home/Armed LED to show the wrong status (from 5.220)
  2. Arm by KNX (1-bit) and Cbus Security Application does not work
  3. Event log on Telephone menu is also shown on all LCD keypads
  4. Scheduled Reminder Messages do not work at the correct time (from 5.173)
Please download firmware file from http://www.cytech.biz/product_details.php?item_id=210
Note that products may not come with the latest firmware when bough from distributors. Please check the website or forum for the latest firmware and upgrade
 Posted: Thursday Nov 24th, 2011 01:37 am
A bug has been discovered in Firmware 6.006
Those who are using Cbus or KNX UCMs and other UCMs which have this function please downgrade to ULT 6.005
A new firmware will be released to fix this
 Current time is 01:50 pm
