Changes in Siren behaviour during Alarm - Speaker SPKR sound is set to Lower Level during alarm dial out so as to minimise interference with the dial out and detection of DTMF and tones for CMS and Voice Phone. Not affected if dialing via UCM/GSM
- Siren SRN output is muted for short intervals during alarm dial out so as to minimise interference with the dial out and detection of DTMF and tones for CMS and Voice Phone. Not affected if dialing via UM/GSM. Not affected if dialing via UCM/GSM
Known Issues
- When dialing in by GSM, using the voice menu 2.4 to leave a message, the MSG LED is not turned on, althoogh a message is recorded. Very Minor problem, which has existed from very old firmware.
- When dialing in by GSM, and a Greetng message is recorded AND local phone is in use, the voice is not heard.
Bugs- F8 Intercom When receiver press 0 to talk then originator press 0, it cannot talk.
- Comfort does not send siren parameters to slave for non-alternating tones
- Slave Strobe does not work
The current firmware file can be downloaded from http://www.cytech.biz/firmware.html
Instructions for upgrading Comfort Firmware can be found at http://www.comfortforums.com/forum4/1782.html
Please note that new systems may not come with the latest firmware due to existing stocks in the supply chain. Installers should upgrade to the latest firmware before installation. Existing installed systems do not need the upgraded firmware unless the funcgtionality is to be updated or there are bugs to be fixed which affect the installation.
