Posted: Tuesday Aug 24th, 2010 03:06 am |
The new firmware ULT 5.202 has been released, replacing 5.199 beta.
Bug Fixes- SCS ID 9 to 15 can now report temperature to the relevent sensor registers
- Fixed issue of two troubles occuring, and 2nd trouble cleared but 2nd trouble is still announced on sign in until both troubles are cleared.
New Fetaures and Improvements- When there is a trouble condition, sign in to the menu will announce the trouble twice; The first time the new trouble condition is announced, followed by the priority trouble and parameter, eg Phone Trouble, .. Zone Trouble, Zone 8 Welcome, Security Off..." This ensures that the trouble condition and its parameter eg Zone Trouble and zone 8 are correct. Or Phone Trouble Restore, Zone Trouble Zone 8 if Phone Trouble has been restored and Zone Trouble 8 is still active (applies for firmware 5.186 to 5.202)
Known Issues
- When Show Alarms is off, alarm causes siren to turn on for 2 seconds ie show alarms 2 secs
- If KP is not connected but No of KPs >0, doorbell will not ring phones until KP is connected
- C-Touch arm keys do not work if set to Special Function > Security Arm (to Away, Night, Day, vacation). M! and m! commands wothout code cannot work. Instead, as a workaround, use Spoecial Function > Security Keypad , select keys Away, Night, day or Vacation for the onscreen keypad to arm the security system.
Note that systems will not come with the new firmware due to the delay in ordering and supply . Installers can upgrade the firmware to the new version if required.
Posted: Saturday Aug 28th, 2010 11:53 am |
I assume the "5.212" in the posted message is a typo!
Answer from Cytech - Yes its an error, corrected.
Posted: Tuesday Aug 31st, 2010 05:19 am |
mrtae
Posts: | 41 |
Chiu,
All the while firmware below V5.202 before this the SCS ID 9 to 15 was unable to be report the temperature to the relevent sensor registers?
Posted: Tuesday Aug 31st, 2010 11:44 am |
Posts: | 1200 |
Correct, it was a bug in temperature reporting of SCS 9 to 15 but apparently no one has used the higher numbered SCS for this purpose
Posted: Thursday Sep 16th, 2010 08:24 am |
We have just reported a bug in firmware versions 5.186 to 5.202
In C-Touch, a Keypad key programmed as Special Function > Security Arm (to Away, Night and Day) wil not work.
The arming keys should be changed to Special Function > Security Keypad > and arm to Away, Night, Day or Vacation
This is a workaround for the bug which will be fixed in the next firmware version
