Posted: Sunday Jan 10th, 2010 03:44 pm |
Podro
I have an Ultra II that is at firmware version 5.054 and I want to install an MPU01 and then bring my system up to the latest firmware version so I can use the sunrise/sunset functionality.
I have read a lot of the posts on the forum about installing the MPU01 which seems straightforward...
http://www.comfortforums.com/view_topic.php?id=303&forum_id=16&highlight=mpu01
But then I got confused as to whether I need to upgrade my UCM firmware from it's current version 5.092 as per the comment in this post "It is recommended that UCM firmware 5.178 and above be used for firmware download" which looks a little more complicated.
http://www.comfortforums.com/view_topic.php?id=1216&forum_id=4&highlight=mpu01
Basically, what I need to know is from my current firmware versions can I just plug the MPU01 in as per the first post and then upgrade the comfort firmware from Comfigurator? Or, do I need to upgrade the UCM firmware as well and if so do I do that from Comfigurator or with the cables (which I don't have) as per the second post?
Sorry if these are basic questions, but I don't want to get this wrong given the consequences.
Thanks,
Paul.
Posted: Monday Jan 11th, 2010 01:44 am |
Posts: | 5493 |
The earlier Comfort II boards with firmware less than 5.100 require an MPU01 plug in to upgrade their firmware (to a version higher than 5.100)
You do not need any UCM for this physical upgrade. The MPU board contains the new firmware.
However once you have the MPU board with the new firmware (currently 5.172), any further upgrades can be done using a UCM with firmware 5.178 and above. The old UCM01 cannot do this. Hence if you would like to upgrade Comfort firmware in future to newer versions you need a new UCM/232, UCM/USB or UCM/Ethernet
If you do not have a new UCM, you can also buy MPU01 with newer firmware in future to replace the one that you have. However later Comfort II PCBs without the MPU header around the U1 IC do not have this option and must use the UCM for firmware upgrades
You should request from your supplier that the MPU has 5.172 firmware installed
Posted: Monday Jan 11th, 2010 06:52 am |
Posted: Saturday Jan 16th, 2010 09:28 pm |
Podro
I tried to do the upgrade of the MPU01 today. I followed the instructions as per the first link in the psot above, powered down the unit, removed the battery, installed the MPU01 as directed and removed the J14 jumper.
When I powered the unit back on I got a communications error. I am sure it announced communication error 33, but I may be mistaken. It was a little noisy as all the sirens and alarms started going off. It stated communication error on the keypad and also showed "slave".
I repeated the whole sequence of events to make sure the MPU01 was seated properly and in the correct location and it definitely was and couldn't be pushed in any further.
I got the same issues when the system was powered back up. I removed the MPU01 and installed the jumper again and the system is normal again.
Any ideas what may going wrong?
Thanks,
Paul.
Posted: Sunday Jan 17th, 2010 08:47 am |
Posts: | 5493 |
What is the MPU firmware? Check the label on the MPU IC which gives the type and version, eg ULT 5.172. There are MPUs for Slaves (SEM) which are not for the main Comfort
The MPU has to be plugged in the right way with the triagle marking aligned. It is possible to plug in 180 degrees the wrong way
When it is plugged in, what is the state of the LEDs on the Comfort PCB?
Posted: Sunday Jan 17th, 2010 09:09 am |
Podro
The label states ULT 5.164. I know you advised me to ensure that it was at the latest version, but I had already bought this before I posted the topic.
Having a thorough read of the forum last night it appears others may have had similar problems and that I may need an MPU-SEM for the slave? Although I couldn't find one of those at the CBUS shop where I bought the MPU-ULT.
One other issue I noted last night when setting the alarm was that the red 'Arm' LED on the keypad did not light, despite the fact that the alarm was set in Night mode.
Regarding the state of the LEDs on the Comfort PCB can you instruct me exactly which ones to look at as this is the first time I have been inside the unit itself. Most of my time previously has been spent on the Comfigurator side.
Thanks,
Paul.
Posted: Sunday Jan 17th, 2010 09:18 am |
Posts: | 5493 |
Do you have a old Comfort I Slave? Slave version 4.95 and older are not compatible with Comfort II, see http://www.comfortforums.com/forum78/1712.html
This needs an upgrade, not an MPU if yours is a Slave for Comfort I, but a upgrade IC01-SEM IC to replace the microcontroller IC
Please confirm what Slave you have. You can read the label on it "SEM4.XX" for Comfort I or "SEM5.xxx" for Comfort II
Posted: Sunday Jan 17th, 2010 01:07 pm |
Podro
I figured it out. I had put the MPU01 on the slave and not on the main board. Don't tell anyone!
I coudn't see the IC's for either as they are covered by other PCB's. When I investigated to look for the slave firmware as you instructed I could see that the IC I had plugged into said SEM 5.033 and the main board IC stated ULT 5.0XX (can't remember the exact number).
I installed the MPU01 in the correct place and it all appears to work fine now.
I assume I don't need to do any form of upgrade to the SEM IC now the ULT is running at 5.164?
Also, I assume I haven't damaged anything by plugging the MPU01 onto the SEM?
Thanks for your prompt responses, on a Sunday as well.
Paul.
Posted: Sunday Jan 17th, 2010 01:36 pm |
Posts: | 5493 |
According to the Slave Compatibility table, SEM 5.033 will work Ok with ULT 5.164. You should not have any problems
Plugging the MPU into the slave should not damage it
Posted: Sunday Jan 17th, 2010 05:22 pm |
Posted: Tuesday Aug 24th, 2010 03:57 pm |
Posts: | 557 |
Can I upgrade my MPU01 while it's plugged into the Comfort II Main board? Will I damage anything if I connect the programming cable to the MPU01, shunt PP2 and then upgrade it via my UCM/Ethernet?
The reason for asking is if I have to dismantle my Slave board and move all the wires and stuff one more time I am surely going to break something soon.
Posted: Wednesday Aug 25th, 2010 12:56 am |
Posts: | 5493 |
You can upgrade the MPU01 while it is plugged in. Switch off the Comfort and remove battery before you conect the programming cable.
You will hear beeping noises on the keypads and speakers
Posted: Wednesday Aug 25th, 2010 04:58 am |
Posts: | 557 |
Thanks.
PS. The strobe also goes haywire... Don't do this too often at night, someone might just try to 'rescue' you.
Posted: Wednesday Aug 25th, 2010 03:59 pm |
My telephones all start ringing too so have to disconnect the TelOut first too.
Posted: Friday Aug 27th, 2010 03:19 pm |
Posts: | 557 |
And what happens next???? I realised that PP2 is underneath my Expansion board and I have to disable everything anyway.
Posted: Friday Aug 27th, 2010 04:02 pm |
IMHO you can leave that jumpered (I do on mine) and leave the cable attached to the MPU so long as you disconnect the UCM end (the 2 connectors).
Posted: Saturday Aug 28th, 2010 05:15 am |
17th Post |
Posts: | 5493 |
It is recommended to remove PP2, but in most cases you can leave it connected, unless you get commuications problems on the RS485 bus
Posted: Saturday Aug 28th, 2010 10:38 am |
18th Post |
Maybe you could develop a small low profile adapter that would enable us to do a remote shunt for scenarios where the PP2 jumper is ofter obscured.
I'm thinking basically of a short twin-wire cable with one end you can slip onto the PP2 connector (low profile no higher than the normal jumper itself) and the other end that you can short/un-short somehow; maybe a small switch etc (I'd even be happy twisting the wires together temporarily! ). Perhaps the wire would be 6 inches long say to clear any obstructions.
Personally I have the "PP2" problem not only for the main PCB (as I have a LEM fitted as a daughter-board) but also on my UCM05, Ethernet too (which has not only the ETH01 daughter-board fitted but also the AUD plugin on top of that too. The UCM is a real pain to keep taking apart every time I need to flash it as the PP2 is just too obscured to be able to jumper it in situ and the connecting bars and screws fiddly.
Of course maybe redesign the boards in later prints to move the PP2 to be more accessible would be even better for new customers.
My thoughts anyway.
Posted: Sunday Aug 29th, 2010 05:04 am |
19th Post |
Posts: | 5493 |
The PP2 header on later UCMs are accessible due to a slot on the daugherboard being added
In future hardware, we aim to remove the need for the PP2 header completely although that is not much help for you
The KT03 will be the first to be without a PP2 header. Just plug in the PP1 6 way cable to upgrade its firmware
