Comfort II Firmware 5.172
 Posted: Tuesday Nov 3rd, 2009 05:03 am
Bug Fixes
  1. Fixed Bug Allow Do Action 88 to be recorded in Event Log
  2. Fixed BUG that when alarm is announcing zones repeatedly , incoming GSM is not answered.
  3. Fixed Bug in dialout  from 5.154 to voice phone which hangs up did not time out and end call if no busy, dial tone or dtmf tone is detected
Known Bugs
  1. Reminder Message on Door Station will play on all keypads and Door Stations
  2. UCM DA Do Action 200 Open Door causes system reset
  3. Clear Answer Machine Bypass (Program menu 1,0,0) also clears Call Screening of calls on Keypad 1
  4. BUG from 5.113 Daylight saving change may occur on wrong day if the change does not occur on the last week of a month.. This does not affect any known country implementing daylight saving
  5. Bug from 5.145 UCM Set Counter > 128 did not work, activat\ed counter 0 to 127 instead
  6. When all user codes  are erased and default  1234 is used, it  does not have any duress code.
  7. When an announcement  interrupts KP-DP intercom, menu can be heard on Door station
  8. Recording greeting or reminder message from remote phone was heard on KP #1
  9. If keypad sign in or GSM ended message recording, MSG LED does not turn on
    when UCM/Access logs in, Comfort will broadcast login and login all UCMs
  10. Reminder message in mailbox did not work.
Upgrading Firmware
Note that systems purchased may not have the most recent firmware instaled due to the supply chain. The firmware .cbf file  can be downloaded from here Firmware can be upgraded using UCM05 and Comfigurator. Instructions for upgrading Comfort II firmware can be found in the UCM Manual
if you are upgrading the firmware from an earlier firmware < 5.145, the initial keypad volume may be soft. Enter your code to go into User Menu and press 7 for Volume and enter the value of 50# to set the volume
The Vocabulary should be version 28 at least. Get Kate29.bin from here
Use Comfigurator 3.0x to do a Vocabulary Write to Comfort
 Current time is 06:11 am
