Slave Firmware 7.118
 Posted: Tuesday Nov 22nd, 2016 08:33 am
Known Bugs
  1. Strobe does not work on Slave. This is not a new issue
Bugs Fixed
  1. Fixed bug SEM sent ack 4DH to Comfort which is  only used by KP LCD and caused problems
Changes
  1. Auto Detect LEM03 on SEM. LEM03 can be connected to the last SEM in the system
  2. Suppprt EL EOL query command. Supports software  eol feature for setting of No EOL or Double EOL without use of Shunts (requires new Hardware)
  3. Accept single message from Comfort with 31 zone types at reset
  4. Support ID Button to set SEM ID (if button is present). Requires new hardware
  5. Handle rs485 comms status 92H message
 Posted: Friday Apr 14th, 2017 03:15 pm
cc_uk
This version has been marked beta for a long time now - it is it likely to be released soon?
I note reference to soft EOL - I assume for a future version of hardware?
I thought a LEM03 wasn't supported when a SEP/SEM was in use on the system?
 Posted: Saturday Apr 15th, 2017 07:59 am
Thanks for the reminder. Yes it should be released soon
This will allow Slaves to support LRM03, so you could have
Comfort + LEM01   Zones 1 to 16
SEM  #1 + LEM01   Zones 17 to 32
SEM #2 + LEM03    Zones 33 to 56
There should be no more Slaves after the LEM03
Hence if you had a Comfort with LEM03 and you want to add more zones, you can still use the LEM03
Yes the Soft EOL is for a future hardware where the zone shunts are eliminated
 Posted: Saturday Apr 15th, 2017 03:27 pm
cc_uk
That's great that a LEM03 could run off a SEM. Presumably though not if there are the full three SEMs on the system?
 Posted: Sunday Apr 16th, 2017 06:48 am
There should only be 1 LEM03, attached to the last SEM in the system, or to Comfort if there are no SEMs
 Posted: Monday Apr 17th, 2017 07:12 am
LEM03 cannot bre connected if there are 5 SEMs in the system as that would edxceed the maximum 96 zones
 Posted: Monday Apr 17th, 2017 04:22 pm
SEM 7.118 firmware has been released
LEM03 can now be connected to the last SEM in the system.
Previously LEM03 could only be connected to Comfort if there are no SEMs in the system
see topic http://comfortforums.com/forum91/2069.html for LEM03 zone numbering system
 Posted: Saturday Dec 2nd, 2017 08:34 am
Note that The Strobe output does not work on the Slave, ie when the Comfort strobe output is turned on, the Slave strobe does not turn on. A firmware upgrade will change this behaviour
 Posted: Tuesday Dec 12th, 2017 03:50 pm
There is a bug discovered in SEM 7.118 (and before)
The Strobe on the Slave does not turn on together with the Strobe in Comfort. A new firmware will be released to fix this
 Posted: Tuesday Dec 12th, 2017 04:03 pm
SEM 7.119 beta can be downloaded from http://www.cytech.biz/product_details.php?item_id=221
This fixes the Strobe problem
 Current time is 06:24 pm
