How to Upgrade SEM Firmware
 Posted: Friday Oct 14th, 2011 04:15 pm
schford
Comfort is on latest 6x UCM Network again on latest 6x ..
New board is going in the attic so though I would be smart(hah) and upgrade it first :-)
Sticker on it says current firmware is SEM 5.139
Thought easiest way of doing it would be just to plug a 485 cable into it which I thought would give me 12v ov and the data bus.
Green light appears and then flashes.
I fire up Configurator go to modules then scan for new slave. - Get an error message "Communication Error or Comfort or UCM Firmware does not support scan"
Think to myself maybe as its such old firmware - so then I try to upgrade it from the UCM using the programmign cable but keep getting upgrade error.
So now am a bit stuck - anyone tell me how to do it?
Stuart
 Posted: Friday Oct 14th, 2011 04:24 pm
schford
I tried removing the 485 cable to upgrade it - it didn't work but comfort did tell me slave one had lost communications.
I am really stumped now!
Incidentally I manually added Slave 1 to comfigurator and synced and now sem green light is solid.
 Posted: Friday Oct 14th, 2011 04:39 pm
schford
yay all done I found http://www.comfortforums.com/view_topic.php?id=1782&forum_id=4&highlight=sem+upgrade
IS it worth making a link to it from the SEM firmware forum so no one else makes an idiot of themselves like I do :-)
 Posted: Friday Oct 14th, 2011 08:28 pm
You have just done the link!
To summarise, Slave and other modules with firmware less than version 6 need to be upgraded using the UCM programming cable, see http://www.comfortforums.com/view_topic.php?id=1782&forum_id=4&highlight=sem+upgrade
Once at version 6, the programming cable is not necessary, the modules can be upgraded using Comfogurator and UCM by Direct Connection if it is the UCM itself of By Comfort Bus see http://www.comfortforums.com/forum92/850.html
 Current time is 05:36 pm
