Comfort Automation/ Security System Forums > Support > Firmware History > Slave Firmware > Comfort I Slave Firmware Compatibiliy with Comfort II
 Posted: Monday Jan 4th, 2010 04:12 am
The document Slave Compatibility Table shows which Comfort I Slave firmware versions can be used with Comfort II
Note that Slave firmware 4.95 and older are not compatible with Comfort II. http://www.cytech.biz/slave_firmware_compatibility.html?category_id=99
The firmware can be upgraded to SEM 4.178 by changing the U1 IC. Please contact  support@cytech.biz about this
 Posted: Thursday Apr 14th, 2011 07:30 am
gaynorc
The Slave Firmware Compatibility doucment link is giving me a 404 page not found error.
Where can I find it?
 Posted: Thursday Apr 14th, 2011 07:44 am
The link has been corrected in the above post
It should be Slave Firmware Compatibility
 Posted: Thursday Apr 14th, 2011 08:22 am
gaynorc
Thank you
 Posted: Sunday Oct 20th, 2013 06:45 pm
mikegriff
I have 2 slave panels running 4.177 from my old Comfort 1 system
I have one other slave which is fully uodated
Would my system work better with Upgraded slave units
I notice that recent firmware updates to the slave units migh mean that my system isn't working to full capacity
Thanks in advance
Mike
Attachment: present comfort.JPG (Downloaded 29 times)
 Posted: Monday Oct 21st, 2013 07:04 am
hendy
Old Slave 4.177 firmware can't be upgraded further.
Sorry but I do not understand the recent firmware update (to slave or Comfort?) might cause the system not to work to the full capacity?
Where did you get this info from?
 Posted: Monday Oct 21st, 2013 09:16 am
mikegriff
Sorry I worded it wrongly
I realised I couldn't update the MK1 Slaves
What I was asking was "For how long will the Mk1 Slaves work?"
I was asking because when you update the firmware on mk 2 Slaves for instance
The changes in SEM 6.068 are
4. RS485 Receive buffer size from 127 to 240 bytes
This must have been done for a reason and is something which cant be done on the MK1 Boards
Mike
 Posted: Tuesday Oct 22nd, 2013 02:49 am
hendy
I think this is more of the question of hardware rather than firmware.
Slave 4.177 is an old one, around 8 years back, so for how long it will continue to work I'd say that it shall work as long as all the components/parts continue to work fine.
As for the increase in buffer size in the new firmware, this is probably to cater for the newer feature introduced in Comfort.
I'm not really sure exactly what the new feature is but this would simply mean that your old Slave I will not be able to make use of the new feature (if any).
The basic function of slave i.e. reporting of zones status should not be affected though.
 Posted: Tuesday Oct 22nd, 2013 09:04 pm
Yes, the increase in message buffer size in Comfort should be to cater for features like Firmware upgrading which do not apply to Slaves anyway, so the version 1 slaves should continue to function as long as it does not develop any faults
 Current time is 02:45 pm
