SEM 5.175
 Posted: Wednesday Oct 21st, 2009 09:17 am
  1. Slave Siren, Strobe and Speaker can be used on Slave
  2. Fixed Bug - initial value of Slave zones reported after reset to Comfort is wrong but subsequent activation is correctly reported. This causes incorrect initial report to Cbus etc
  3. Fixed Bug - Slave zones with Zone Types 17 to 31 all have Sensitivity highest ie 10 ms
  4. Fixed BUG - at reset Slave zones which are ON were reported as OFF then ON
  5. Slave Speaker Output enabled. Outputs same signal as Comfort. Requires Comfort 5.167 and above
  6. Slave STROBE Output enabled. Follows Strobe on Comfort. Requires Comfort 5.167 and above
The firmware can be downloaded from http://www.cytech.biz/semsep_firmware.html
 Posted: Friday Jan 15th, 2010 12:49 pm
jorgecolaco
Where can i download this firmware SEM 5.175?
In webpage there are only SEM firmware 5.163
I need to fix: "Fixed BUG - at reset Slave zones which are ON were reported as OFF then ON", the bug are hapenning in a home and we need to fix it.
Thank you,
Best regards,
Jorge Colaço
Segurant Technician
 Posted: Friday Jan 15th, 2010 06:17 pm
The firmware SEM 5.175 has now been updated at http://www.cytech.biz/semsep_firmware.html
 Current time is 01:39 am
