Comfort System Struck by Lightning
 Posted: Saturday Jul 11th, 2020 09:32 am
david8811
My Comfort system was struck by lightning few days ago. I have just checked and found the following problems:-
1) one of the Keypad AC is lighting up and totally dead. The keypad buttons are not responding.
2) I also found out 6 of the PIRs are not triggering the alarm when activated.
3) The Keypad also announces “ communication failure “ when I key in the engineer menu password.
Can you please confirm what is the problem urgently.
 Posted: Saturday Jul 11th, 2020 10:38 am
If there has been a lightning strike, the comfort pcb had probably been damaged and will need to be replaced.
 Posted: Saturday Jul 11th, 2020 11:51 am
david8811
Thanks for the swift response. Now, I also cannot sign in the engineer menu. There is a message on the keypad says “wrong text push *1 together “ what does it means.
PS: I read in the forum that this is to do with vocabulary update first. My problem is I am still using keypad programming and I do not have the configulator. How shall I solve this problem?
 Posted: Saturday Jul 11th, 2020 02:48 pm
It's the same problem. The board is probably damaged.If it is vocabulary failure you need a ucm to upgrade the vocabulary . It cannot be done by keypad
 Current time is 10:34 pm
