Periodic zone activation, setting of alarm.
 Posted: Saturday Jan 11th, 2020 02:42 pm
sinky100
I have periodic issues with my front door (zone 1) activating. I have re-terminated the door sensor and fitted a new mag switch but I have had another zone activation. I have looked at the log (below and attached) and can see that the zone is reporting activation/restores.
Does anyone has an idea the cause? I don't want to keep bypassing the zone, and leaving the zone unprotected.
Any assistance greatly appreciated. Thanks.
Iain,
01/09 21:31 Sign in - User # System Response
01/09 21:31 Mode Change # Night Mode
01/10 06:32 Zone Activation # FrontDoor (1)
01/10 06:32 Alarm Type # EntryAlert (10)
01/10 06:32 Restore - Zone # FrontDoor (1)
01/10 06:32 Sign in - User # 1
01/10 06:32 Mode Change # Security Off
01/10 21:54 Sign in - User # System Response
01/10 21:54 Mode Change # Night Mode
01/10 23:10 Zone Activation # Backdoor (11)
01/10 23:10 Alarm Type # EntryAlert (10)
01/10 23:11 Restore - Zone # Backdoor (11)
01/10 23:11 Sign in - User # 1
01/10 23:11 Mode Change # Security Off
01/10 23:13 Sign in - User # 1
01/10 23:14 Bypass Zone # FrontDoor (1)
01/10 23:14 UnBypass Zone # FrontDoor (1)
01/10 23:45 Sign in - User # System Response
01/10 23:45 Mode Change # Night Mode
01/11 07:00 Sign in - User # System Response
01/11 07:00 Mode Change # Security Off
01/11 14:49 Sign in - User # 1
01/11 14:50 Sign in - User # 1
Attachment: log zone 1.clg (Downloaded 1 time)
 Posted: Sunday Jan 12th, 2020 01:10 am
The possibilities are
  1. There us a fault on the front door zone
  2. There is a problem with the zone wiring to the dronr door, perhaps loose or interference dfrom pther sources
If you have a spare zone, change the fromt door wiring and programming to the new zone. Or if you do not have a spare zone, exchange the zone with another one to see if the fault changes accordingly
 Posted: Sunday Jan 12th, 2020 07:31 pm
sinky100
Thank Slychiu,
Will transfer the zone wire to a spare zone and see if that makes a difference, plus re-program for the change.
Cheers,Iain
 Posted: Friday Jan 17th, 2020 06:12 pm
Try wiring EOL that will highlight the fault.
 Posted: Saturday Feb 1st, 2020 03:26 pm
sinky100
Thanks. Out of the UK at the moment, so will try this when I get home. Luckily access is good, even if I need to replace the cable.
Cheers,Iain
 Current time is 08:28 am
