Posted: Saturday Nov 1st, 2014 05:08 pm |
macjohnson
Posts: | 4 |
Hi - We had a power failure last week whilst the alarm was set, which triggered the Battery Warning Slave Board 2 warning. We knew the battery was due for replacement, so ordered a new battery and have replaced it today.
However, the red AC and green OFF lights are still blinking and I'm not sure how to reset the system. Can anyone tell me how to do this, and whether or not I will need to reinstall any codes etc if I go through this process.
Many thanks. I have Comfigurator software installed if that is easier to use.
Posted: Saturday Nov 1st, 2014 06:18 pm |
macjohnson
Posts: | 4 |
Fixed it now - found the reset option, took a deep breath and clicked it - was worried it would reset / wipe everything, but it just cleared the problem.
Posted: Saturday Nov 1st, 2014 06:28 pm |
Posts: | 5499 |
Online
That is right
After a slave has a low battery condition, it needs to be reset in order to clear it
It is quite safe to reset the system whenever you want
Imagine if you had a pc which erased the hard disk when you reboot it
Posted: Saturday Nov 1st, 2014 09:13 pm |
macjohnson
Posts: | 4 |
Hah - yes, fair point!
To test the battery I've read that I need to turn off the AC power - is there a simple way to do this? Sorry for such a dull question but we've inherited the system and I'm on a learning curve!
Posted: Sunday Nov 2nd, 2014 06:13 am |
Posts: | 5499 |
Online
If you want to measure the voltage on the battery with a multimeter you should switch off the power. It may be difficult in the UK as it is supposed to be connected to an unswitched power outlet.
To do a system battery test, press F31 on the keypad
This tests the battery by disconecting the AC internally for 2 minutes and running the system on battery. If a low battery voltage is detected, the system reports Battery warning and ends the test. Comfort will do the test every 24 hours from the last bettery test
Posted: Sunday Nov 2nd, 2014 03:48 pm |
macjohnson
Posts: | 4 |
Ok - we have done that, and the voice says "battery test" but nothing seems to happen - I assume this is a good sign and means that everything is ok. Is it usual then to leave the system to test itself every 24 hours indefinitely so that I'd be alerted by phone if it found a problem? Thank you for your help
Posted: Sunday Nov 2nd, 2014 04:31 pm |
Posts: | 5499 |
Online
No result for battery test is good
You can leave the battery test running every 24 hours, but it is not necessary to have Comfort call you, unless there is a power failure at the same time. The weak battery should still work the system for a few hours if there is a power failure
There should be plenty of time to change the battery
