Posted: Friday Dec 27th, 2013 07:56 pm |
Banging32
Posts: | 2 |
I've got an old comfort panel,I think its a comfort pro. The keypad has no display. I'm unable to connect using the configurator software is there a way I can completely default the panel using the keypad ?
Posted: Saturday Dec 28th, 2013 03:28 am |
Posts: | 1200 |
Do you mean that you have lost the user codes?
If so you can use the Engineer code to reset the user code to 1234 as described in http://www.comfortforums.com/forum16/2357.html
You cannot default the whole program back to a blank system
Once you have your user code, you can write the default template to Comfort
Posted: Saturday Dec 28th, 2013 03:17 pm |
Banging32
Posts: | 2 |
Thanks for the help. I know the user code but ive taken the panel from 1 site and installing it some where else. Just wondered if I could default panel and start again from scratch.
Posted: Sunday Dec 29th, 2013 01:10 am |
Posts: | 5499 |
Use Comfigurator and select a default template then write to Comfort to "default " it
Then start again to program with Comfigurator
