Posted: Saturday Oct 22nd, 2011 12:54 pm |
raygregg114
Posts: | 104 |
Hi, Since I upgraded my firmware for my GSM2 board a few weeks ago I am having an intermitting problem. Sometimes the green power light flashes on the keypad. When you type in your code it says SMS TROUBLE RESTORED. You can reset or arm the system and everything is OK. Other times when you turn the alarm off maybe after a few hours or minutes (sometimes it may not happen for a few days) a beeping comes from the keypad, on the keypad it says UCM2. I had powered this from the ETH02 board with the white cable and changed it to the KA, KB etc. but still the same. ttached is a copy of the event log from the system foe today. Any ideas!!!! Attachment: Comfort 221011.PNG (Downloaded 63 times)
Posted: Saturday Oct 22nd, 2011 01:21 pm |
Posted: Saturday Oct 22nd, 2011 02:19 pm |
raygregg114
Posts: | 104 |
Thanks for that, worked perfect.
Posted: Saturday Oct 29th, 2011 08:27 am |
mikegriff
Posts: | 103 |
with new 3.3.3 software Non detector alarm 22 is now dial failure not SMS Trouble
has this made the problem go away?
Mike
Posted: Saturday Oct 29th, 2011 08:38 am |
Posts: | 5498 |
No, the alarm type for non detector alarm SMS trouble should be Null or alarm type 0
Posted: Saturday Oct 29th, 2011 02:25 pm |
mikegriff
Posts: | 103 |
Should i change this entry then Chiu?
I'm getting the flashing green light!!
Sorry for the questions but i cant see where the DailFailure came from!
MikeAttachment: SMS.JPG (Downloaded 43 times)
Posted: Saturday Oct 29th, 2011 02:45 pm |
mikegriff
Posts: | 103 |
Hi Chiu
I think I see what is happening
Are my names set from my original comfort install years ago?
Should I change these all back to the new names?
Mike
Posted: Sunday Oct 30th, 2011 03:46 pm |
There is no need to change any names, as they are just descriptions
Alarm 22"Dial Failure" is the cause of the SMS Trouble intermittent that you have been getting. This is not a real alarm but due to network fluctuations
To get rid of it just set the assigned alarm type currently "ARCCommsFail" to the null alarm (blank)
This should not have been caused by Comfigurator 3.3.3, as that should not affect the alarm type settings unless you start a new default cclx file
Posted: Monday Oct 31st, 2011 01:38 am |
Another point about these intermittent SMS Troubles:
can you check the signal strength of the network bhy shunting SW8-H ? The signal strength is indicated by the 4 leds as shown in the UCM/GSM Manual
If your network strength is low then you should move the module to another location and use two ADM02s to extend the cables
Posted: Monday Oct 31st, 2011 09:58 pm |
mikegriff
Posts: | 103 |
Thanks for feedback will check at weekend and report back
Mike
Posted: Friday Jan 10th, 2014 12:33 am |
and001y
Posts: | 1 |
Possibly anyone using cell blocker around you.
Source from: jammerfromchina.comLast edited on Friday Jan 10th, 2014 12:33 am by and001y
