VoiceProc documents
 Posted: Wednesday Sep 9th, 2020 11:40 am
Sota
I want to replace a few words in the vocabulary, so I downloaded the voiceproc software but I have no idea what to do. The links to the voiceproc.pdf file don't work, so does anyone have a simple guide to just making a few substitutions?
Thanks.
 Posted: Thursday Sep 10th, 2020 05:09 am
The instructions for voicepric can be downloaded from http://www.cytech.biz/voiceproc_software.html
 Posted: Thursday Sep 10th, 2020 08:22 am
Sota
Thank you, I don't know how I missed that! Does it matter that Comfigurator has myma43.bin in the config folder and the myma_IVS.zip file only has myma36.bin?
 Posted: Sunday Sep 13th, 2020 05:26 am
Myma43.bin is the result of Voiceproc existing configuration . When you use Voiceproc, it will create a new .bin file (use a different name)  that you use to upgrade the Vocab in Comfort
 Posted: Sunday Sep 13th, 2020 11:39 am
Sota
I'm sorry, I have weasted several hours on this but I cannot make any sense of the instructions!
I simply want to add the words EnSuite, Rear, Shed, Sliding and Vibration to the Myma list. All of them apart from Back are listed as wav files in the Myma_Highpass.wvd folder, but not in the myma.dat foder.
When I open the myma39.ini in Voiceproc, they are not listed.
Can you explain what exactly I need to do?
Thanks.
 Posted: Monday Sep 14th, 2020 02:27 am
The latest ivs files are attachedfrom myma43.ini
VocabNo=05
VocustNo=255
VocSysVer=43
VocUserVer=1
VocTextVer=2
LCDVer=3
WavesDir=kate.wvd
CompressedDir=kate.dat
VCD_Quality=mid
VocabularyFileName=kate43.bin
SentencesFileName=sentence36.tab
LCDFileName=lcdkp_v38.cfg
MaxSentenceLength=10
NumOfSysWords=207
SetVol=0.6
TranslationFileName=translat36.tab
NumOfUserWords=141
UserFileName=resid36.tab
NumOfTables=5
[Tables]
Table0FileName=newtab0.tab
Table1FileName=newtab1.tab
Table2FileName=newtab2.tab
Table3FileName=newtab3.tab
Table4FileName=number4.tab
UserFileName=resid36.tabresid36.tab is the file that you have to amend to add or change the words
Rename the file from myma43.bin so you can create a new bin fole
Then use Voiceproc to generate the new bin file
 Posted: Wednesday Sep 16th, 2020 03:56 pm
Sota
I've used the ivs files you sent, and made some progress. I can create a bin file which uploads OK to Comfort but I can't get the words to appear in Comfigurator. Also, the options to save user word file and to Save ini file are greyed out in VoiceProc.
Loading the myma43.ini file from above gives these errors:
Opening C:\Temp\VoiceProc\myma43.ini
[General] =
VocabNo = 05
VocustNo = 255
VocSysVer = 43
VocUserVer = 1
VocTextVer = 2
LCDVer = 3
WavesDir = kate.wvd
CompressedDir = kate.dat
VCD_Quality = mid
VocabularyFileName = kate43_custom.bin
SentencesFileName = sentence36.tab
LCDFileName = lcdkp_v38.cfg
MaxSentenceLength = 10
NumOfSysWords = 207
SetVol = 0.6
TranslationFileName = translat36.tab
NumOfUserWords = 141
UserFileName = resid36.tab
NumOfTables = 5
[Tables] =
Table0FileName = newtab0.tab
Table1FileName = newtab1.tab
Table2FileName = newtab2.tab
Table3FileName = newtab3.tab
Table4FileName = number4.tab
WORD_PAGER cannot be found
Error looking up word in C:\Temp\VoiceProc\number4.tab line# 34 : WORD_PAGER WORD_CODE
WORD_EVENT cannot be found
WORD_LOG cannot be found
Error looking up word in C:\Temp\VoiceProc\number4.tab line# 47 : WORD_EVENT WORD_LOG
Error looking up word in C:\Temp\VoiceProc\number4.tab line# 48 : WORD_EVENT WORD_LOG WORD_ERASED
WORD_DELETE cannot be found
Error looking up word in C:\Temp\VoiceProc\number4.tab line# 59 : WORD_DELETE WORD_MAILBOXES
Error looking up word in C:\Temp\VoiceProc\number4.tab line# 79 : WORD_PAGER WORD_DIAL WORD_OK
WORD_ANSWERING cannot be found
WORD_MACHINE cannot be found
Error looking up word in C:\Temp\VoiceProc\number4.tab line# 110 : WORD_ANSWERING WORD_MACHINE WORD_BYPASS
 Posted: Thursday Sep 17th, 2020 05:38 am
You may be working from an old comfiguration
Please use the attached configuration files
The message  shows where the error is found
Error looking up word in C:TempVoiceProcnumber4.tab line# 34 : WORD_PAGER
This means that number4.tab file referes to PAGER WORD but the words cannot be foundThis could be due to the old configuration
 Posted: Thursday Sep 17th, 2020 08:36 am
Sota
OK, I give up on this, it's just a mess. That's the same file as you already sent me, and the dates on the files go back as far as 1996!
I'm using Comfigurator 3.13.5.0 with the latest version of the VoiceProc software and all I want to do is replace a few words in the vocabulary. There are three different dat folders which seem to have different selection of words and the documentation is useless.
 Posted: Thursday Sep 17th, 2020 08:39 am
 Sorry, it is not easy to follow and not easy to explain without spending a lot of time If it is just a few words I suggest you just use what you have
 Posted: Thursday Sep 17th, 2020 08:40 am
Sota
That's what I will do, thanks for trying :)
 Posted: Wednesday Sep 23rd, 2020 01:32 pm
Sota
I gave this one more shot and finally got it working. The ivs.zip file above is out of date, but I got the most recent one from the downloads on the web site.
Everything is now working, with one small exception. The KP04 keypad downloaded the new vocabulary immediately but the KP06 still has the old one - for example it shows store instead of shed. Pressing 1 and # does not update it.
What have I missed?
 Posted: Sunday Sep 27th, 2020 12:16 pm
13th Post
Sota
I eventually discovered that you have to press 1 and * (not #) to download the vocabulary on the KP04.
 Posted: Monday Sep 28th, 2020 01:46 am
14th Post
Yes it is *1. This should automatically take place after the vocab upgrade, but you can pres *1 to force it
 Posted: Monday Sep 28th, 2020 07:08 am
15th Post
Sota
It happened automatically on the KP04 but not on the KP06, even after resetting the system. I had assumed the keys to reload were the same on both keypads.
Anyway, that is the end of my system upgradess, so hopefully I won't be bothering you too much from now!
 Current time is 12:47 pm
