Text data error
 Posted: Tuesday Mar 14th, 2017 01:21 pm
Julian.Driver
I'm not sure if this is the correct area of the forum for this.
I have recently uploaded an amended configuration file. It seems to be working OK but the keypads have 'No text data download aborted' on the screen.
If I reset the system and try to upload the file again  I get ' The wordlist selected is different from the vocabulary programmed in comfort. Do you wish to continue with the transfer?'
I am using Comfort II Ultra v7.099, file system 34 vocabulary number 255 with no custom vocabulary. System and user vocabulary are shown as '0'. UCM is 10 version 7.076.
What do you recommend to fix this?
 Posted: Tuesday Mar 14th, 2017 04:24 pm
Do the keypads have voice menu when you sign in?
When system is reset the keypads should say "Security Off"
If no voice, then you need to do a Vocab Transfer
If you have voice, reset and do System Information again
You should not get vocabulary version 255
 Posted: Tuesday Mar 14th, 2017 07:32 pm
Julian.Driver
There is no voice on sign in, so it seems that a vocab transfer is required. I assume I use myma.bin for that?
 Posted: Wednesday Mar 15th, 2017 09:36 am
yes use myma39.bin
It should already be in comfiguratror when you go to Transfer > Upgrade vocabulatry
 Current time is 08:10 am
