Comfort Automation/ Security System Forums > Support > Problems & Troubleshooting > Vocabulary Issues > System Error No vocab entry found for Standard residential
 Posted: Saturday Feb 25th, 2017 03:59 am
timop001
Upgrading to Comfort II with a board I bought back in 2010 (don't ask why it has taken so long!)
Using Comfiguratior 3.11.10.0.Upgraded the ULT34 firmware to latest 7.xx
Translated the previous .ccl fileover to .cclx ULT34.Notice some words used previously have change so amended them but system basically works other than Comfigurator throwing System.Exceptions errors reading vocust.cfg (see attached screen shots). No entry found for Standard residential. I have tried to change this to English residential in Comfigurator but doesn't seem to have an effect.
Also the system report seems to show all them vocabulary parameter as 0...
Do I update Comfort II vocab? Sentence only?If so which files do I use??
Attachment: Error.PNG (Downloaded 25 times)
 Posted: Saturday Feb 25th, 2017 04:00 am
timop001
Sys info show vocab entries all "0"
Attachment: SysInfo.PNG (Downloaded 25 times)
 Posted: Saturday Feb 25th, 2017 06:14 am
Is the keypad voice working when you sign in? zero entries for vocabulary  ,ay mean that vocab was lost
 Posted: Saturday Feb 25th, 2017 01:04 pm
timop001
Keypads and phone vocab all working fine. Some words changed from previous set up so selected alternatives which work. Just this confit error. Wondered if it was that the board vocab is out of date.
 Posted: Saturday Feb 25th, 2017 04:23 pm
There may be an error in your config
pls send your cclx file to support@cytech. biz for investsigation
 Posted: Sunday Feb 26th, 2017 11:56 am
the file seems file and the System Information also shows the correct values below
English residential is the correct vocabulary assigned
If you do Transfer > System Information again it should show the same parameters
Attachment: vocab.jpg (Downloaded 19 times)
 Posted: Sunday Feb 26th, 2017 05:44 pm
timop001
Thanks Chiu
The problem was that even after a reset Comfort was reporting 0 for vocab fields.
However I think I have SOLVED this. I was using my old UCM01 to do the programming whilst my UCM05 was away having a firmware update. I understood from the Comfort II compatibility list that *all* UCMs were compatible.
It appears that the UCM01 v5.43 IS NOT and cannot read Comfort II vocabulary settings through the Comfig 3.11.10. I am using. Changed back to the UCM05 v7.xx and the vocal is reported correctly.
Is there anyway to easily upgrade the UCM01 firmware ?
 Posted: Monday Feb 27th, 2017 05:55 am
I am glad you figured that out
UCM01 is not compatible with Comfort 2 according to the Compatility list at http://www.comfortforums.com/forum16/1470.html, relevant points below
  • UCM01, UCM/IR, UCX01, UCM/Ethernet - Not Compatible. Also UCM01 cannot be used to upgrade firmware of other Comfort Flash based modules. UCM/USB is part of Upgrade packages 1 and 2
  • Other UCMs eg CBus, EIB, Smartfit - compatible. However the firmware of these UCMs cannot be upgraded like the newer Comfort II modules
The UCM01 hardware is different from the new UCM so a firmware upgrade is not possible
 Current time is 06:07 pm
