Vocab corruption?
 Moderated by: slychiu Page:    1  2  Next Page Last Page
 Posted: Thursday Jan 5th, 2017 01:15 pm
idheath
I have a strange issue with my system.
When someone leaves a message and I replay it the date/time stamp is corrupted.
For example I would hear something like this, rather than the hrs/mins.
"Wednesday Wednesday Wednesday PM"
Any thoughts.
 Posted: Thursday Jan 5th, 2017 04:13 pm
This may be due to the sentences being corruipted
Try doing a Sentence Tale upgrade, and select the latest vocab file
Make sure you comfort firmware is up to date, as some old versions had a problem with sentences upgrade
 Posted: Thursday Jan 5th, 2017 04:15 pm
idheath
Thanks, will try that.
 Posted: Thursday Feb 2nd, 2017 08:20 pm
idheath
Oops I think I went a bit wrong!
I just did a Vocab Upgrade (using kate39.bin) and now the words seem to be all mixed up, i.e. the prompts are all wrong via the keypad/communicator!
 Posted: Friday Feb 3rd, 2017 06:13 am
did the vocab upgrade complete successfully?
what does the Transfer> system information screen say
 Posted: Friday Feb 3rd, 2017 10:51 am
idheath
The transfer seemed to work ok (it did stop near the end and ask me whether I wanted to start from where it stopped, which I did do).
The System Information screen says:
Firmware Type: Comfort II Ultra
Version: 7.116
File System: 34
Vocabulary Number: 5
Custom Vocabulary: No
System Vocabulary Version: 39
User Vocabulary Version: 1
LCD Text Version: 2
LCD KP Minimum Version: 3
For reference the system says "Seven Zero Alert" when I exit the voice menu with the F key, rather than "Security Off".
 Posted: Friday Feb 3rd, 2017 11:17 am
System info seems to be correct
Can you just do a Sentences table upgrqrade instead of the full vocab upgrade
 Posted: Friday Feb 3rd, 2017 11:34 am
idheath
I tried that too, and no change.
I've also just tried myma39.bin and I still have the same issue.
 Posted: Friday Feb 3rd, 2017 11:44 am
It appears like some fault on the comfort unfortunately
I have not encountered that before
When was it purchased, do you have serial number?
 Posted: Friday Feb 3rd, 2017 11:52 am
idheath
I got the board shipped directly from you I think, after inadvertently buying a non-official one from that supplier in the UK.
Then I got a repair from you in 2014 due to a lightning strike in July 2014
http://www.comfortforums.com/view_topic.php?id=3880
Is the serial number only visible on the actual PCB?
 Posted: Friday Feb 3rd, 2017 12:06 pm
Hmm, it was a lightning strike which caused  a fault on your original comfort. Is your area prone to lightning? Instead of damaging the system completely, it may have caused some random fault. Have you tried switching off the system and removing the battery?
 Posted: Friday Feb 3rd, 2017 01:08 pm
idheath
Yes I think it was the cause of the fault the first time, damage close to the telephone interface I recall.
We're not prone to lightning at all here, that was a one-off I think.
I just tried a complete power down / battery out and it's still the same.
 Posted: Monday Feb 6th, 2017 04:09 pm
13th Post
idheath
It's a bit of a strange fault. Only some of the vocabulary is wrong.
 Posted: Monday Feb 6th, 2017 05:41 pm
14th Post
That is very strage. we cannot figure out what would be causing that
can you give an exacvple of the words which are wrong, ie the correct word vs the wrong word
 Posted: Monday Feb 6th, 2017 05:45 pm
15th Post
idheath
Would it help if I sent you some wav files?
 Posted: Monday Feb 6th, 2017 05:53 pm
16th Post
wav fikles are OK but just the name of the words would be sufficent
 Posted: Monday Feb 6th, 2017 06:03 pm
17th Post
idheath
These are the files I have.
1 = Me keying *<PIN>#
2 = The loop message after the above
3 = Me pressing the F key to end/logoff
4 = Setting night mode then disarming
5 = Setting away mode then disarming (including walking through a zone)
I can't upload a WAV file, can I sent them to admin@comfortforums.com, if not please PM me an address.
 Posted: Monday Feb 6th, 2017 06:33 pm
18th Post
Support@cytech.biz
 Posted: Monday Feb 6th, 2017 06:43 pm
19th Post
idheath
Have just sent them.
 Posted: Wednesday Feb 8th, 2017 09:11 am
20th Post
idheath
Any news?
 Current time is 08:57 amPage:    1  2  Next Page Last Page
