VPG02
 Posted: Friday Nov 4th, 2011 08:35 am
kodomo
How to use VPG02 for make a new Vocab and new wordlist?
 Posted: Friday Nov 4th, 2011 09:03 am
VPG02 is used to transfer a vocabulary into Comfort, eg Myma, Kate or others which have been wriiten into the Flash Memeory IC onboard the VPG02
This is much faster than using Comfigurator to upgrade the vocabulary taking 5 minutes instead of 20+ minutes
To make a new vocab and word list you need to use the Voiceproc and Voiceplay software, download from http://www.cytech.biz/voiceproc_software.html?category_id=98
There is an instruction  document in the same like which explains the whole process
The vocabulary words and sentences are processed by Voiceproc and needs to be wriiten into the VPG flash memory. Then you cab use VPG02 to traasfer the vocabulary to Comfort
 Current time is 01:29 pm
