Comfigurator
 Posted: Saturday Nov 30th, 2013 07:03 pm
What rules determine whether this message below is displayed (tried both 3.7.6 & 3.7.7) when you try to execute a response. Even though I've saved all config back to Comfort and reset it STILL keeps asking me this question. Getting pretty fed up of this check now!
Attachment: err.bmp (Downloaded 38 times)
 Posted: Tuesday Dec 3rd, 2013 05:41 am
The conditions are
  1. When the Response has more than 24 bytes, it needs to use R! command rather than DA commands to execute the response
  2. The current configuration has changed since the current Comfigurator session started or the complete configuration was written to Comfort within the current session.
The 2nd rule means that if you made a change to the configuration during the session, it will ask to write responses again even though you have already done it
That probably needs to be changed so that it should not ask if the configuration has not changed since the last write
 Posted: Tuesday Dec 3rd, 2013 07:18 am
So this is a bug?
I couldn't find a way around it even though I'd just done a full write to comfort and immediately then pressed the execute button on the response.
 Posted: Tuesday Dec 3rd, 2013 07:23 am
Yes it is a bug
The simplest workaround is to just answer No to the question, the response will be executed, if you are sure you  have not made any changes to the response
Or If you load the cclx file and execute response it will not give the message
 Current time is 11:58 pm
