Cannot connect to new UCM/Eth03
 Posted: Wednesday Jul 22nd, 2015 07:16 pm
BCS
I've just upgraded my Eth02 to an Eth03.
The Eth02 was working OK but I want to use Comfort Mobile, which I understand only works with an Eth03.
Anyway, I powered the UCM down, removed the Eth 02 and plugged in the Eth03.
Repowered the UCM and all the lights came on as expected.
Comfort Server Manager finds the Eth03 and I've changed the IP address and confirmed it's Ok by pinging it.
When I try to scan for new UCM's, using the appropriate IP address and port (I've tried both 1001 + 1002 plus others), I get failed to connect to UCM.
Plugging the Eth02 back in corrects the problem  so I'm a bit confused and not sure where to go from here.
Any help or ideas would be much appreciated.
Neil
 Posted: Wednesday Jul 22nd, 2015 07:24 pm
Make sure you are on the latest UCM and Eth03 firmware.
 Posted: Wednesday Jul 22nd, 2015 09:39 pm
BCS
Thanks Ingo - That worked a treat - A bit embarrassed I didn't think of it :?
Cheers
Neil
 Posted: Wednesday Jul 22nd, 2015 10:11 pm
No worries, a while ago there was a compatibility issue between certain older versions of the two firmwares.
 Current time is 06:13 am
