Comfort Automation/ Security System Forums > Products > UCM > UCM Problems > couldn't connect to ucm Ethernet
 Posted: Tuesday Apr 17th, 2012 03:11 pm
m.khairy
i have ucm Ethernet 5.2
i upgraded it to 6.012
the ucm led indicators works normally
ds manger reads ip
when i enterd the ip & port to the comfigurator , this message appears : couldn't connect to ucm
i tested the MJ101 , i found a short between pins 7&8
is this the problem ?
 Posted: Wednesday Apr 18th, 2012 02:54 am
Was the UCM working befiore upgrade to 6.012?
Is it ETH01 (orange module) or ETH02 (silver)
MJ101 pins 7 and 8 are not connected so iut should not cause a problem
Are D9 and D10 leds  both  blinking?
check the shunts in SW8 - F should be shunted if ETH01 and Not shunteed if ETH02
 Posted: Wednesday Apr 18th, 2012 10:26 am
m.khairy
the UCM wasn't working before upgrade to 6.012
it is ETH01 (orange module)
& the SW8 - F be shunted
 Posted: Wednesday Apr 18th, 2012 10:30 am
m.khairy
sorry ,
the message appears : no response from ucm
 Posted: Wednesday Apr 18th, 2012 11:28 am
Do you have a firewall? if so shut it down and see if you can connect
Firewalls are one of the main reasons for blocking the UCM/ethernet
 Posted: Wednesday Apr 18th, 2012 12:26 pm
m.khairy
i don't have a firewall
 Posted: Thursday Apr 19th, 2012 04:00 am
Can you send a screenshot of the settings in DS Manager? Please send to suppport@cytech.biz
 Posted: Thursday Apr 19th, 2012 09:06 am
m.khairy
i sent a screenshot of the settings in DS Manager to suppport@cytech.biz
 Current time is 04:58 am
