Comfort Automation/ Security System Forums > Products > UCM > UCM Problems > ETH02 Connection Timeout setting
 Posted: Wednesday Oct 26th, 2011 09:44 am
gaynorc
On the ETH02 I purchased this august, the "connection timeout (min)" entry in DS Manager was set to 5 minutes.
In the UCM manual downloaded from Cytech the diagram shows the "connection timeout (min)" set to "0=Disabled".
Which setting do you advise for use with ETH02?
 Posted: Wednesday Oct 26th, 2011 09:57 am
This should be set to 1 minute especially if used for iPhone
It disconnects if there is no communications for the idle time so it avoids a device hogging the connection
Only 1 connection at a time is allowed to the UCM/Ethernet
It is also good for security so that someone cannot pick up the phone or computer and control your system
The new firmware/application for the ETH02 should also be used
 Current time is 03:16 am
