Posted: Sunday Aug 21st, 2011 12:25 pm |
dcrera
About 8 months ago my UCM went faulty and was replaced with a newer firmware version.
Prior to the change my C4 interface worked flawlessly.
Since the new board, I have no connection to C4.
Upgraded to all the newer versions since still no connection.
I have the luxury of having 2 UCMs with the interchangable sister serial/ethernet plug ins.
I failed hopelessly trying to connect to DS Manager hoping to use Comfort on my Ipad with the ethernet UCM . Refer
http://www.comfortforums.com/forum65/2424.html
I decided to give my C4 a bash again armed with 2 UCM's.
The only time I get any response on C4 is when I press the reset button on the UCM.
I noticed each UCM version reports differently on press of the reset button
Version 6.0.0.7
Without Shunts
00000000 03 52 53 31 31 0D .RS11.
00000000 03 44 54 32 30 31 31 30 38 32 31 31 34 30 31 33 .DT2011082114013
00000010 33 46 46 0D 3FF.
00000000 03 56 3F 46 45 30 35 44 41 32 32 32 30 30 31 30 .V?FE05DA2220010
00000010 30 0D 0.
00000000 03 5A 3F 33 30 32 30 0D .Z?3020.
00000000 03 61 3F 31 31 30 30 30 30 30 30 30 30 30 30 30 .a?1100000000000
00000010 30 30 30 30 30 0D 00000.
00000000 03 4D 3F 30 30 30 31 0D .M?0001.
With Shunts G & H
00000000 52 53 31 31 RS11
00000000 44 54 32 30 31 31 30 38 32 31 31 34 30 32 34 33 DT20110821140243
00000010 46 46 FF
00000000 5A 3F 33 30 32 30 Z?3020
00000000 4D 3F 30 30 30 31 M?0001
00000000 61 3F 31 31 30 30 30 30 30 30 30 30 30 30 30 30 a?11000000000000
00000010 30 30 30 30 0000
Version 5.192
With out Shunts
With shunts G & H
00000010 30 0D 03 5A 3F 33 30 32 30 0D 0..Z?3020.
So it got me thinking, are these UCM's downward compatable ?
I have lost funcationality by upgrading ?
Where can I source the older firmware versions ?
Posted: Sunday Aug 21st, 2011 12:45 pm |
Posts: | 5498 |
No, new firmware adds functionality, not removes functionality.
see UCM firmware history forum http://www.comfortforums.com/forum81/
We need more precise information about your problem
I dont understand what you are attempting by inserting shunts G and H
Shunt G will remove the STX character
How are you connected, by Ethernet or RS232?
Do you still have problem with the IP address detection by DS Manager?
Then how are you able to see the below data with C4 (do you mean Control 4?)
You can downgrade to previos firmware
send an email to support@cytech.biz
I think it is better to resolve your ucm/ethernet problem first so as to avoid confusing the issue
Posted: Sunday Aug 21st, 2011 01:02 pm |
dcrera
Hi Chiu,
Control4 needs G/H (either one or both) to work.
Connected to Control4 via serial RS232.
- YES (sent email)
- When C4 is connected to the serial UCM in debug mode you can see all the chatting.
