Posted: Friday Aug 19th, 2011 05:45 pm |
dcrera
I am having a field day with my UCM comms.
I installed DS Manager 5.8.5
My UCM 6.0.0.6 ethernet , F is shunted
My CPU has been updated with the latest firmware.
I have 4 port DSL router. Firewall turned off.
My network cannot auto discover the ethernet UCM.
What's the configuration ?
Anybody knows of a network discovery tool > I am runng windows XP
Posted: Friday Aug 19th, 2011 05:52 pm |
Did you get the ds manager from Cytech or Tibbo website? Chiu told me (and I witnessed) that one version of the program on the Tibbo website had a problem and couldnt see the ucm. Just a thought.
There is a DS-Explorer tool on the Tibbo website (part of Tibo IDE) that you could try too I guess.
I must admit it sounds like firewall or maybe one of these more advanced antivirus suites blocking!
Posted: Friday Aug 19th, 2011 08:49 pm |
Posts: | 557 |
I sometimes get the same but then I just use my old XP Laptop and connect via a crossover cable to the UCM.
Posted: Saturday Aug 20th, 2011 08:26 am |
Posted: Saturday Aug 20th, 2011 09:51 am |
dcrera
I turned off anti virus check and the firewall.
Still can't see UCm
The Tibbo software was downloaded from Cytech
Plugged a Laptop to the same router port I intend using for the UCM. Checked what IP address the port is using.
Reconected same port to UCM with same IP address. Still can't find.
Loaded DS Manger on a WIN 7 laptop with a direct connection to UCM. Bitched about the firewall. Turn it off and again nothing.
Used another spanking new UCM I got yesterday with version 5.212 and the sister ethernet board.
And again, can't auto discover.
Why me I ask with tears in my eyes.
I tried all access methods. Should I be using the In Band TCP with port 1001 ?
Thanks for all the feedbacks
PS : Could not find DS-Explorer toolon Tibbo website.
Post url if available
Posted: Saturday Aug 20th, 2011 10:16 am |
Posted: Saturday Aug 20th, 2011 11:49 am |
dcrera
I am using Escan for my Virus protection. Currently all disabled.
Found this neat software that will show you port/ip usage on the router.
http://www.angryip.org
IP 10.0.0.4 is one I should be using but no ping on that IP. But DS Manager shows an ? next to the IP 10.0.0.4 address indicating that someting is there.
Posted: Saturday Aug 20th, 2011 12:38 pm |
Can you post a screenshot of what you are seeing in DSManager.
The TCP/Port question should not stop you seeing the UCM in ds manager in the first place though.
Posted: Saturday Aug 20th, 2011 04:19 pm |
Posted: Sunday Aug 21st, 2011 06:34 am |
Posted: Sunday Aug 21st, 2011 10:27 am |
dcrera
Hi Julian
Sent to your email address.
File size issues
Posted: Sunday Aug 21st, 2011 07:59 pm |
Incidentally, I think this should not be in the ComfortClient forum as it's more to do with the UCM connectivity from DS Manager. Admin, should this be moved to a different forum?
Posted: Monday Aug 22nd, 2011 03:07 am |
Posts: | 1200 |
Thats correct, This has nothing to do with ComfortClient
I have moved it to Troibleshooting > UCMs
Posting in the appropriate forum will assist in resolution as it alerts the moderators of each forum, and allows users to quickly find any post
This problem may be to do with your network Perhaps it is not connected in the same physical network so DS Manager is unable to find
As you have said, changing to old firmware does not fix the problem so the new firmware is not an issue
Also check the LEDs on the Ethernet daughterboard, and refer to the UCM Manual
http://www.cytech.biz/ucm_manual.html
Perhaps there is no power to the module
Posted: Monday Aug 22nd, 2011 07:42 am |
dcrera
Sorry for posting in wrong thread.
The UCM manual I read is slightly different from this. I will go over it again.
But just browsing thru it and I am sure I did not miss much. I check and feed back
Posted: Monday Aug 22nd, 2011 03:57 pm |
dcrera
Connected the UCM with the ethernet cable supplied to my DSL router.
Ensured F was shunted
Did auto discovery on DSM and it did not pick up any
Monitored status lights on Tibbo module D101 and D104 off
D102 steady with single blink
D103 two blinks (green)
Tested with board version 6.007 and 5.192
Posted: Wednesday Aug 24th, 2011 10:55 am |
Posts: | 5493 |
Refer to the UCM Manual http://www.cytech.biz/ucm_manual.html
Table 2.5 shows the meaning of the LED indicators on the Ethernet board
This shows that the connection is closed
There may be a physical conenction problem
Try connecting the UCM/Eth directly to the PC using a crossed ethernet cable
Posted: Monday Sep 5th, 2011 06:11 pm |
17th Post |
HenleyBranch
Posts: | 75 |
Hi, I am interested, did you resolve this problem?
I am a newbie, but having carefully followed the instruction manual, am now checking this forum as I seem to have exactly the same situation. Turned off all anti-virus and disabled firewalls, downloaded DS manager from the Cytech site, tried connecting via two different routers and then a switch, but DS manager doesn't see the UCM - ETH02. Lights are on as per the manual so I am presuming the unit thinks it is on the network. Tried directly to PC with crossed cable but still nothing. What am I doing wrong? Getting very frustrated as all I want to do is program my alarm! Probably making a silly error.
Posted: Monday Sep 5th, 2011 09:55 pm |
18th Post |
HenleyBranch
Posts: | 75 |
With a crossover cable and the IP of my virtualised PC (Parallels - All Firewalls and AV disabled) and the IP address set of the PC fixed at 10.0.0.5 - I get a little question mark on 10.0.0.57 (see attached). Is this the UCM? When I double-click it, I get a message "There was no response from this device". Any suggestions? Attachment: 2.jpg (Downloaded 52 times)
19th Post |
Posted: Tuesday Sep 6th, 2011 04:48 am |
20th Post |
I suggest you get a replacement for the UCM, and try it. I dont know why it would not be auto-discovered if you have switced off the firewalls. Are you sure that you have no firewals at all?
Current time is 09:08 am | Page: 1 2 |
