Intermittent Alarm Trigger After Few Days
 Posted: Friday Jun 26th, 2015 10:38 am
joshua963
Restricted
I'm having this issue whereby the client's home which is currently vacant has this issue of Alarm Being Triggered Intermittently.
I have 2 questions here :
1) How do I check the event log on the keypad from Engineer Menu ?2) How do I set/reduce the Zone Sensitivity from Engineer Menu ?
I don't have the UCM with me at the moment. Please advise.
Thank you.
 Posted: Friday Jun 26th, 2015 10:52 am
Press F+5 on the keypad. No need to go to engineer Menu, although you can refer to Engineer Menu programming manual
You cannot change zone sensitivity from engineer menu easilyChoose a different zone type instead
If you are programming using keypad download worksheet according to Optimum or Ultra models from http://www.cytech.biz/worksheets.html
You also need the Engineer Menu Programming manual from http://www.cytech.biz/engineer_menu_programming_manual.html
It is recommended to get a UCM and use Comfigurator for programming, it would be much easier
 Posted: Friday Jun 26th, 2015 02:06 pm
joshua963
Restricted
Going through the event log, the latest triggered zone should be announced the first right ?
 Posted: Friday Jun 26th, 2015 03:00 pm
The event log starts from the earliest event
The date and time is announced  before each event You can navigate by pressing 1 for next, 2 for previous, 3 for next day, 4 for Previous day, 0 for 1st event, 9 for last event
if you use UCM and comfigurator to read event log then you can save it as a file
 Current time is 07:25 am
