Alarm Strobe
 Posted: Friday Sep 9th, 2011 05:33 pm
strickers
Sorry if this is easy but am new to this. I have now got my comfort alarm system functioning correct apart from one thing. While testing my set-up to see if it all worked OK I purposely caused an alarm. This caused the bell and strobe to operate but when I enter my code to re-set the alarm I can not stop the strobe. I have reset comfort from comfigurator and this doesn’t work either. At the moment the only way I can stop the strobe once the alarm has gone off is to disconnect the battery and mains power.
Any advice would be much appreciated.
Update - I thought the strobe was only going on after the alarm had been triggered but the strobe is always on when it has power.....
 Posted: Saturday Sep 10th, 2011 02:42 am
Could  have connected the strobe  wrongly?
The Hookup diagram can be downloaded from http://www.cytech.biz/hookup_diagram.html
The srobe should only have power when the alarm is triggered and it should turn off when the alarm is disarmed.
 Posted: Saturday Sep 10th, 2011 09:53 am
strickers
Hi Thanks for your reply.
It is now fixed. I had a spare bell that I was going to wire on the other side of the house. I swapped them and now all is good. I'll return the bell and get a new one.
 Current time is 11:15 am
