Posted: Tuesday Jul 21st, 2009 08:34 am |
incontrol
Posts: | 19 |
Having just up graded a comfort project from comfort I to II using the new Keypad KP04-wi , comfort II Ultra Firm ware 5.145 since the change setting the alarm has the following results
1/ setting the alarm to away mode form the keypad (one touch padlocked) no response
2/ Setting the alarm via a remote key fob, using the response ‘autoArmAway’ set’s the alarm, with NO arming tone on key pad, however it announces the alarm state after the final set.
3/ Setting the alarm to night mode using the Moon key , no arming responses , but arms to night mode.
I have checked:
The arming and disarming settings, after exit delay 20sec, exit time 20sec
Keypad settings ,
Any ideas
Richard
Posted: Tuesday Jul 21st, 2009 12:21 pm |
Posts: | 4449 |
Richard
You have replaced Comfort I with a new Comfort II PCB?
Have you started a new file system using File > New with Comfigurator 3 and then transferred to default settings to Comfort II?
It looks like a problem wiith parameter settings that you describe which using a default file should fix.
Posted: Tuesday Jul 21st, 2009 01:04 pm |
incontrol
Posts: | 19 |
Hi Chiu
Yes I have replaced comfort I with comfort PCB II,
I did a convert file system, you think this could be the problem, ok I’ll try using the default file ( the job’s remote , but I have a CWM02 part installed)
I have another query ,I have the CWM02 I’m having problems with my browsers Java application , whilst on the java.sun.com site ( to test the java ) this works,
But when I try to connect to comfort web server the browser announces no java. If I look at my advance menu in explorer does not resemble the settings of the cwm02 manual . any pointers on this would be great
Posted: Tuesday Jul 21st, 2009 01:35 pm |
Posts: | 4449 |
Which version of IE or other browser are you using?
Posted: Tuesday Jul 21st, 2009 01:59 pm |
incontrol
Posts: | 19 |
Internet Explorer 8
Posted: Tuesday Jul 21st, 2009 02:30 pm |
Posts: | 4449 |
Can you also test with another browser say Firefox? see if you get the same message?
Posted: Tuesday Jul 21st, 2009 02:43 pm |
incontrol
Posts: | 19 |
Both browsers, would first display, the log in after stating that java is not supported , I would get the keypad log in with a yellow triangle with an exclamation mark inside the triangle .
The keypad would except my login but no screen would change
Now that I have a fix for the arming, I’ll have to revisit and try the java logging again.
Posted: Wednesday Jul 22nd, 2009 02:57 am |
hendy
Posts: | 221 |
It is strange that you can see "Sorry, your browser doesn't support java" message and the keypad log-in page both at the same time. If it does not support java then the keypad log-in page should not appear.
Can you go to this site: http://java.com/en/download/help/testvm.xml to see if the correct java version is installed.
You should be able to see the "Duke" dancing if it is okay. Else, you should only see a grey box.
Another thing is to ensure that the number of UCMs programmed by Comfigurator is correct. By default, the ID of CWM = 2 so the number of UCMs should equal to 2 if there is no other UCM in the system.
You should see both red (485 TX) and green (485 RX) LEDs on CWM02 flashing fast if it is programmed correctly; otherwise, only the green 485 RX LED will flash and the red 485 TX LED will remain off.
Posted: Wednesday Jul 22nd, 2009 01:05 pm |
incontrol
Posts: | 19 |
When I did the browser check, I got the dancing duke,
Just checked the ccl file only one UCM is checked,’opps’ I’ll change this when I’m next on site
Richard
