Autoarm fails..
 Posted: Monday Feb 16th, 2009 12:14 pm
Manas
Hi friends,
I just finished installing MinderPro(comfort) at a residence. I have not given any keypad. Instead, I use 2 NO switches for the control purpose.
The first switch arms system(uses 'Autoarm Security Night' function). Second switch disarms system along with putting siren off('Autoarm Security Off', 'Siren Off').
Whenever I program the board or restart it manually, It goes into night mode by pressing 1st switch. Works well.. Gives alarm on zone detection. When I press 2nd switch, siren becomes off and security becomes off.
Now when I press 1st switch to arm security again it fails to do so. I don't have keypad so god only knows what error might be occuring...
Please suggest..
I am attaching program for your reference.
Regards,
Manas
Attachment: vkaha_new_1.ccl (Downloaded 10 times)
 Posted: Tuesday Feb 17th, 2009 12:07 am
Not having a keypad is definately not a good idea. You are correct that only God knows what is happening
You can try to find out what happened by checking the Event log. Do TRansfer > Event Log
 Posted: Tuesday Feb 17th, 2009 04:02 am
Manas
I found a link while searching.
http://www.comfortforums.com/forum36/1143.html
The problem resembles to the one at my site. Only difference is that I don't have kp.
I will try to upload the Event Log and post reply as early as possible.
 Current time is 12:46 pm
