Are you sure that it does not work? Did you do a Security check F,3,2 and test the sensor?
How are the EOL setting for the zone? I suggest to set for NO EOL resistors and do not connect any EOL resistors
If it does not get detected, measure the voltage between the zone and common when there is no motion and when there is motion
the voltage should be 1.2V if no motion and 0V if there is motion (approximately) with NO EOL resistors and shunts accordingly
