Posted: Thursday Jan 3rd, 2013 12:56 pm |
m.khairy
Posts: | 32 |
i have connected the i/p with current sensor , But How to detect o/p status on event log?
Posted: Thursday Jan 3rd, 2013 07:19 pm |
Posts: | 562 |
I think 'Output Status' is not an Eventlog trigger event. See the Protocol Documentation for all events written to the log.
Posted: Friday Jan 4th, 2013 02:06 am |
Correct, the event log is meant for security events only, not for automation
However ULT firmware version 7 has a new action Save to event log (need Comfigurator 3.6.2) in Response Wizard > Misc
This action has a parameter 0 to 255
so you can add an action Save to EventLog 1 to the outputN Response
The Event log will show the event recorded with the output or any other action
This is good for troubleshooting purposes
Posted: Friday Jan 4th, 2013 02:32 am |
Posts: | 562 |
Ident,
Can you please send me the command format for this new feature, I couldn't find it in the latest protocol documentation.
Also, from which firmware version will this be supported?
Thanks,
Posted: Friday Jan 4th, 2013 03:03 am |
This is not a change in protocol, it is a new action code and so is found in the Action Codes Reference http://www.cytech.biz/product_details.php?item_id=147
Those with a gmail email account, can get access to the Cytech Resources folder which contains the updated manuals, documentation, software etc
Posted: Friday Jan 4th, 2013 03:13 am |
This action is supported in ULT 7.005
Posted: Tuesday Jan 8th, 2013 10:05 am |
m.khairy
Posts: | 32 |
thanks for reply ,
can i delete event log ? or adjust the time that i want to be saved ?
Posted: Tuesday Jan 8th, 2013 10:13 am |
You can delete event log using keypad, Engineer Menu 5 for event log, 0 to erase Event log
The time stamp in the Event Log is based on the system time
You can adjust that using Program Menu 2 for date and time, or by Comfigurator Transfer Menu
Posted: Tuesday Jan 8th, 2013 01:30 pm |
m.khairy
Posts: | 32 |
I make "code=34,param=0" for detecting o/p status OFF
And "code=34,param=1" for detecting o/p status ON
my question is : how can i rename the text appars on event log (unknown event) to as example (light on) ??
Attachment: event log.JPG (Downloaded 35 times)
Posted: Wednesday Jan 9th, 2013 05:00 am |
Copy the attached file eventlog.cfgx into your comfigurator\config folder
This will cause the event log to show "Custom Event # 0" or other event number instead of Unknown event, 34
Custom Event means it is a custom event with parameter 0 to 255
You will have to know what each parameter stands for in the event log, as this is a method of troubleshooting events triggered by Comfort
The new Comfigurator 3.6.3 will include the event eventlog.cfgx file
Attachment: eventlog.cfgx (Downloaded 12 times)
