LEM01
 Posted: Sunday Apr 15th, 2012 09:37 pm
brianza
I have a LEM01 connected to an ULTRAII.
All my 16 Zones work well but today I needed to use Output 9 and this did not work. I actually have 16 outputs in total (and am using 4 relay units).
I know that outputs 9 onwards are not working as I cannot hear the relay click when activated. On the other hand Relays connected to outputs 1-8 (that is those directly on the UltraII board) work just fine.
Besides connecting the ribbon cable is there anything else that I needed to do to enable the outputs 9-16?
rgs
Brian
 Posted: Monday Apr 16th, 2012 01:05 am
There is no setting required to enable the Outputs on the LEM
If the Outputs 1 to 8 work, try exchanging the OP1 betweeen the LEM and Comfort
Switch off power and battery to Comfort before unplugging the OP1s
 Current time is 01:26 pm
