Keypad doesn't show night mode status
 Posted: Wednesday Feb 20th, 2008 11:35 pm
Tas
My LCD kepads no longer indicate the status of Night Mode. I beleive that they used to indicate Night Mode by displaying the mode name on the LCD display and the red ARM led. However, the green OFF light remains lit and "Ready to Arm..." remains frozen on the LCD display. Strange thing is Away Mode doesn't have this problem.
The last thing I did was a vocabulary update from Anita to Kate, and some minor response changes. The Vocab update died halfway through and I had to run it again. The keypads needed *1 to download new text... could this have caused the problem.
I also did some renumber of responses to tidy up the configuration... Are there any fixed ones I shouldn't be removing?
Thanks for your help,
Tas
 Posted: Wednesday Feb 20th, 2008 11:38 pm
Tas
I forgot to mention that Night Mode is actually active...  activating protected zones triggers the alarm.
Thanks again,
Tas
 Posted: Thursday Feb 21st, 2008 12:53 am
hendy
Perhaps you put too many responses associated with night mode? If so try to break them shorter by introducing delay (use timer).
 Posted: Thursday Feb 21st, 2008 09:31 am
See the post in http://www.comfortforums.com/forum36/930.html
Check your night mode response and temporarily set to Null, see if the problem persists
If it does, send us your ccl file to support@cytech.biz
 Posted: Thursday Feb 21st, 2008 08:31 pm
Tas
Thanks for the help. This was the problem. Introducing timer delays has resolved the problem.
 Current time is 11:48 pm
