Test KP06
 Posted: Thursday Oct 4th, 2018 07:44 am
Ian
I have 4 keypads two of which are KP06. One is KP06 and the other KP06A.The KP06A was fitted recently and the number 9 does not always activate when pressed unless pressed more firmly that the others. Can I swap the small keypad module from the KP06 to the KP06A to test if it is the small module or the whole keypad that is at fault?
Cheers
Ian
 Posted: Thursday Oct 4th, 2018 07:56 am
The keyboard module can be interchanged between KP06A and KP06The LCD modules cannotIf the KP06A keyboard has a faulty button it can be replaced if you confirm
 Posted: Thursday Oct 4th, 2018 08:05 am
Ian
Thanks. I will do a swap and test when I get back.
 Posted: Thursday Oct 4th, 2018 11:48 am
Ian
Faulty key!
 Posted: Thursday Oct 4th, 2018 11:58 am
Can you check with the distributor if they have a spare keyboard module?
 Posted: Thursday Oct 4th, 2018 12:03 pm
Ian
I will, thank you.
 Posted: Thursday Oct 4th, 2018 12:43 pm
Can you send an email to support@cytech.biz? with yoiur name, and address and contact number
we will replace the keyboard directly. Is it white or silver ?
 Posted: Thursday Oct 4th, 2018 12:51 pm
Ian
On its way - thank you.
 Posted: Friday Oct 5th, 2018 09:12 am
The replacement module has been sent out
 Posted: Friday Oct 5th, 2018 10:47 am
Ian
Thank you
 Posted: Tuesday Oct 9th, 2018 12:35 pm
Ian
Keypad arrived, fitted and appears to be working.
Thank you.
 Current time is 01:24 pm
